Old 28-12-2005, 08:49 AM   #1 (permalink)
yrana2002's Avatar
Default Play avi on VCD
I have a 1.3 GB avi video file that i want to play on my VCD player. What are the best ways to do that? Also, which medium will give the best experience? Converting it into which format? I have a DVD player as well.
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
Old 28-12-2005, 09:04 AM   #2 (permalink)
dIgItaL_BrAt's Avatar
converting it into a DVD would be a better option,cuz if u convert it into a VCD u will definetly lose some quality.
BTW,is that file a DivX/XviD movie rip? Just curious....
dIgItaL_BrAt is offline
Old 28-12-2005, 12:19 PM   #3 (permalink)
JGuru's Avatar
Use Nero for converting and burning. First of all reduce
the size of the Video using software like 'VirtualDub'.
Bring it to 500 or 650 MB (Compress the Video)
In Nero choose -> Make a Video CD.
It will do the conversion for you . Have some patience
it's gonna take a long time!!
You can make SVCD or DVD using Nero provided that
you have the Nero Ultra Edition OEM edition with you.
Bear in mind that conversion to SVCD or DVD would take lot of System resources and time,
4 hours or more in fact.
JGuru is offline
Old 28-12-2005, 09:07 PM   #4 (permalink)
yrana2002's Avatar
What if i convert it into a DVD format & then load its image through Alcohol or some other software like that?
Which format should i convert it into?
Is the avi format good enough? Which is better?
Old 29-12-2005, 07:17 AM   #5 (permalink)
Gracias Senor
dreams's Avatar
I hav abt 30 GB of pure Vids and movies in DivX Format.. I tried the conversion method in Nero. For a single movie it takes abt 1 1/2 Hours to complete.
But the Output S***S. So waste of time. Then i came to knw abt 2 Giants.. VirtualDub n TMPGEnc.
These 2 does the job with ease.. same amt of time taken but the Output is same as the Original. Ther r lots of steps 2 b followd to get the original quality. But worth doin it. Now i play all the movies n SONY Player.
NOTE - All vids i made it in VideoCD Format since i dont hv a DVD Player.
..nJoy..
dreams is offline
Old 29-12-2005, 07:25 AM   #6 (permalink)
nil_3's Avatar
@ JGuru
Will you please try not to be so bold in writing!
nil_3 is offline
- by Krow
