Old 27-12-2005, 05:27 PM   #1 (permalink)
Default WHY IS THIS HAPPENING?
I installed VLC media player from nov issue of digit.Whenever i start a clip or any media file first the picture pauses while the time doesnot stops.When again i restart i can hear the voice of the first clip going on.But task bar doesnot show window of vlc player.Further when i turn off my pc,a window appears depicting vlc is going on if i press cancel or close my pc hangs .Why is this happening?
EVERYBODY WANTS TO GO TO HEAVEN BUT NOBODY WANTS TO DIE
mandar5 is offline
Old 27-12-2005, 06:32 PM   #2 (permalink)
do u face the same problem with any other player? play the same file in windows media player or powerdvd and reply back pls.
/legolas
legolas is offline
Old 27-12-2005, 11:17 PM   #3 (permalink)
Default no
No all other media files work finely.I had heard that vlc can play ne media file in ne format.Hens i installed it.
mandar5 is offline
Old 27-12-2005, 11:40 PM   #4 (permalink)
Try reinstalling...
Or why u use that just use Media Player 10..
Its good enough...
Computer.
Whats that.
Is it some kind of frog.. turr turr turrr...
con_tester is offline
Old 28-12-2005, 11:41 AM   #5 (permalink)
yes, VLC rocks true.. did u try the version 0.8.4 the latest one? hav a try coz i dont see any prbs with ur comp as no other players face the same problem.
/legolas
legolas is offline
Old 28-12-2005, 01:15 PM   #6 (permalink)
Default thanks
Can i get that for free and if yes then from where?
Cheers,
mandar5 is offline
Old 28-12-2005, 02:06 PM   #7 (permalink)
yes of course, its free! go here or go to download.com and search "vlc player"
/legolas
legolas is offline
- by Krow
