Old 27-12-2005, 05:22 PM   #1 (permalink)
Default copying dvd to cd...
guys, i have a dvd which has 5 movies in it. i want to write one of those movies on a cd so that cd player can play it.
plzz tell me how to do it....
thanxx...
abhishekkalra is offline
Old 27-12-2005, 06:20 PM   #2 (permalink)
hansraj's Avatar
use the software dvd x and has good capabilities to convert dvd to either vcd format or div x format... rest are available but this one is the lightest and the best in terms of quality...
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 27-12-2005, 06:35 PM   #3 (permalink)
ok, u hav a 5 in 1 DVD. the vob files in it wil be separate for all movies. what i mean is, suppose there are 2 vob files for 1 movie, then u can choose those 2 vob files to copy to ur hardisk and then use auto gordian knot to rip them to a CD size... and auto gordian knot when installed has a tutorial link given under the start menu. so u neednot panic reg. the how to's! gl. however, i personally doubt the quality of a movie from 5 in 1 DVD to be that good! even to watch it straight... with ripping i wudnt even dream of!
/legolas
legolas is offline
- by Krow
