Old 19-10-2004, 01:51 AM   #1 (permalink)
gxsaurav
Posts: n/a
Default Which AV is for U
Although I had a bad experience with KAV personal, it made me reinstall Windows, but that could have been due to my mistake or something
No matter which AV U use, their engine is pretty much same, they do pretty much same way of doing a trick, when U launch an application the AV detects the code being executed for viruses, so this make app launching & opening a bit slow, but it’s still unnotable on system with sufficient RAM
NAV 2K5, which I m using does slows down the app launch a bit, but it’s pretty much a 0.1 or 0.2 % lag, highly un noticeable, it typically runs 5 services in my system, which combined use about 20 MB RAM, now that may seem high for NAV but on my system with 512 MB RAM it’s not notable in Windows, 2D environment, I never go below 300 MB free RAM in 2D windows, although when browsing a lot of WebPages it goes down to 250 MB free RAM
Each game recommends that when U play the game U disable any Anti virus running in background, this is due to the reason that game is full of code running at all times, & if the AV is on, each code is examined on the fly which for game can be bad, U can have about 10% performance decrees, no matter which AV it is
If U do not use Internet, & do not use floppy or CDs to share files, then U don’t need a AV, it’s useless, there is no other way a virus can come to your PC. I use cable internet which is LAN based, when I m not using the net, I disable the LAN which disables my internet, also since I m not on Internet & disable the NAV2K5 Auto Protect, how else a virus can come to my system, if I use a CD while not connected to internet I simply enable the AV software, & scan it, after that disable it again before copying
Just as an example, take a CD & copy the files while your AV Auto protect is on, measure the time, then reboot to free up memory & this time copy again while the AV is off, U will see the files copy fast, the reason for this is that your AV software is examining each code & data on the fly while it is being copied which slows down a process
If U are paranoid about your system being slow due to an AV software, then here are a few measures U can use
1) Disable Auto protect of your AV if U R not connected to internet
2) Disable AV & end task all the services & exe that the AV is running when starting to play a game, this helps a lot
3) Enable your AV before inserting floppy & CD to be protected from Boot viruses on FAT32 Systems, scan it, if nothing is found then disable the AV & then copy
Now coming to the main thing NAV vs KAV, the list can go quite long so I m just writing the pros & cons of both, add more if U find any
NAV 2K5, pros
Most compatible, works with everything, reputable, standard in AV market, less user interaction required, easy to update via Live Update, quick delectation, protection from Internet worms & trozen before they enter with IWM, good for n00bs, archive scanning, eats about 3% CPU resources, fast individual file or few files scan, detects Adware & malware, trozans. Frees RAM automatically when required, in case of games, unpacks any setup exe on the fly & then scans inside, protects E-Mail & Office documents
NAV 2K5, cons
Slows app launching a bit, slows game about 5% when played with Auto protect on, to much RAM eating, not for systems with 128 MB RAM, unnotable on 256+ RAM based system, too many features are not used often, no way not to install a feature, but it can be disabled, really pain in the a** if uninstalled, as it leaves a lot of registry keys, which have to manually removed from a registry cleaning software, slow with full system scan, ADware & malware detection not up to the mark compared to Spybot or AD-Aware SE
KAV Personal Pro 5.012, pros
Less running services & low on RAM usage, good delectation engine & rate, low user interaction required, hourly updates for the Virus definition, less bloated as it comes with AV only, detects trozan & adwares, unpacks any setup exe on the fly & then scans inside with UPX, protects E-Mail & Office documents
More by Indyan, as he knows it better then me
KAV personal Pro 5.012, Cons
More user interaction then NAV 2K5, RAM usage can fluctuate pretty high, but then lowers, transparent scanning in the background, slows app launch a bit, slows games a bit, not the most compatible out there so there can be incompatibility cos it’s still new, not very reputable so low on user trust, not so good updating engine, slow individual & full system scan compared to NAV2k5, doesn’t scan every archive format, buggy with installed after un-installation of a previous AV software (this made me reinstall Windows)
No matter which AV U use, I prefer that U also use a firewall software with it like Sygate or Zone Alarm, with a good Adware removing software like Ad aware or spybot, the combo is unbeatable
I use NAV2K5 standard, with Sygate Personal firewall pro & Ad aware SE, I disable NAV IWM cos Sygate is better then IWM as firewall
If U have enough RAM & using NAV rite now then keep it, but if U reinstall Windows due to some reason, then before using NAV give KAV a try, U may like it
Old 19-10-2004, 02:11 AM   #2 (permalink)
sunnydiv
Posts: n/a
my experiance, kaspersky so so so so damn slow
notrton 5, didnt try yet
avg, fastest scanner i have ever seen
Old 19-10-2004, 02:32 AM   #3 (permalink)
da' Ťurntable ruleth
techno_funky's Avatar
Panda Rules silent assasinator
me using it for some months after giving up on MAV
faster updates
and the best thing not resource hungry
| Dell Studio 15 | iPod Touch 16GB (Stolen) | iPod Video 5.5G 30GB | Sony Ericsson W910i |
| Sennheiser PX 100 | Sennheiser HD 202 |Creative EP630 | Altec Lansing ATP 3 |
techno_funky is offline
Old 19-10-2004, 04:04 AM   #4 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
me fully satisfied with NAV 2005... works fine with my 512 MB... and i hardly play games on my laptop!
never tried KAV... heard a lot about... thinking to tryout in hostel pc as i reach campus after vacs...
nice pros and cons counted by gx...
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 19-10-2004, 06:13 AM   #5 (permalink)
The Photoshop Guy
cooljeba's Avatar
AVG
..:: peace ::..
Jeba
cooljeba is offline
Old 19-10-2004, 06:40 AM   #6 (permalink)
I am using Zone Alarm Antivirus Scanner....Any Comments abt this GxSaurav ??
19000 Members & Counting ....
Click Here To Join India\'s Second Largest Community
http://www.sansite.info/
Wizard is offline
Old 19-10-2004, 07:48 AM   #7 (permalink)
ice
U guys didnt talk bout symantec corp. av 9.
Its their latest Corporate one , with the windows 3.1 look.. No BMP/Gifs, no eyecandy, email scanning, on the fly exe scanning, the works,
Doesnt carry a spyware detector, but most of us would just use spybot/ad-aware and be happy with them.
Live update is the Normal NAV one, i presume, but seems faster. Low on resources.
Last statistics.
I get 100fps in counter strike, with the AV running, and 98 while its scanning for virii. And 94 when i was DVD ripping and running a system scan.
If u guys want, i could post a few screenies.
A lot hasnt changed since version 8, except now it works better with OE.
ice
ice is offline
Old 19-10-2004, 09:28 AM   #8 (permalink)
gxsaurav
Posts: n/a
What I m tryin here is not another NAV vs other thead or My AV is beTter thread, I m trying to bring in front the pros & cons of your AV, do no hide anything, write everything postive & negative that U like & don't like about your AV, just as I did
Norton has pre-scanner which scane before install which is good, which isn't available anywhere else
I have used Mcafee before so hre is what I think of that
Mcafee 8 Pro, Pros
Don't know any, comes with a firewall which is integrate, good engine, fast with full system scan,
Mcafee 8 Pro, cons
Realy Bad update engine, extremely slow as such, eats a lot of RAM like 32+ MB, slows app launch a lot, tries to install it's own software & bugs U for that
Old 19-10-2004, 12:20 PM   #9 (permalink)
AVG here ...
There hardly is any difference in game speeds while using this proggie ...
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 19-10-2004, 12:33 PM   #10 (permalink)
@gx dude
what happened with ur kaspersky and windows??
No Mercy, No Limits.
theraven is offline
Old 19-10-2004, 01:25 PM   #11 (permalink)
happy with my nav 2003
Attack life, it\'s going to kill you anyway.
walking-techie is offline
Old 19-10-2004, 03:07 PM   #12 (permalink)
gxsaurav
Posts: n/a
As I said earliee, point out the reasons of using a AV insted of other, some are doing it some are not, I like indyans post, as he pointed out pros of KAV over others
the name of this thread was changed as it was becoming a AV software comparision
Old 19-10-2004, 03:11 PM   #13 (permalink)
Well ... AVG
Pros
+ Low on resources
+ Good trojan detection
+ Small update files
Cons
- May not be as thorough as kaspersky or mcafee
Hmm ... i'll give symantec corporate AV a try once.
ujjwal is offline
Old 19-10-2004, 06:26 PM   #14 (permalink)
lavan_joy's Avatar
mm. I'm still sticking with NAV 2005.. Good and takes low resource for me
LAZINESS IS THE ENEMEY OF SUCCESS
lavan_joy is offline
Old 19-10-2004, 07:04 PM   #15 (permalink)
gxsaurav
Posts: n/a
Good to point out these things for AVG Ujjwal
lavan
as I pointed out earlier, if U have RAM then NAV won't bug U
Old 19-10-2004, 07:24 PM   #16 (permalink)
Mcafee for me.
I think AVG/NAV/Kaspersky/AVG/Panda have equally good detection capabilities. So I like to use Mcafee for the ease of use and automation. It updates automatically everyday, without fail. Scans the entire system everyday at 3:00 AM when the computer is idle. Minimum user input required.
wORm is offline
Old 19-10-2004, 08:01 PM   #17 (permalink)
I will stick to mcafee .
Easy installation , Good look , Not much system resourses , Generally dont fail in detection , easy to work with.
So this makes me go with Mcafee
BlAsTeR is offline
Old 19-10-2004, 08:13 PM   #18 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Welll ... All the cafes here I surfed use Kaspersky ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 19-10-2004, 10:13 PM   #19 (permalink)
gxsaurav
Posts: n/a
This was evident, as the features increse so does the RAM usage, NAV used to eat less RAM in the days of NAV 2K1, now there are more features so more RAM usage, thisis not soemthing to shout at
Old 20-10-2004, 01:01 AM   #20 (permalink)
swatkat's Avatar
I use eTrust EZ AV.It's good.
http://swatrant.blogspot.com/
swatkat is offline
Old 20-10-2004, 01:47 AM   #21 (permalink)
sms_solver's Avatar
Earlier I have been using Norton AV 2003
Now I use AVG
I might try kaspersky
is seems that Norton is loosing it foot over AV market.
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 20-10-2004, 01:44 PM   #22 (permalink)
Gxsaurav,I have to disagree with you. NAV2005 is a real system resource hogger.I have 512 MB RAM, and I still have to wait 3 mins extra during boot up, for the damn 'engine' to load up. Enabling it causes the whole system to go sluggish. So I enable it only while surfing, after which I leave it disabled. And I do perform a system scan every 5 days or so....NAV2004 was much faster while booting and never was a resource hogger. Well you can't blame them when almost everyone has a 3Ghz PC in the US. Bloatware is a must for pushing processor speeds!
DON\'T waste money on expensive ipods. Simply think of your favourite tune and hum it. If you want to \"switch tracks\", simply think of another song you like and hum that instead.
gamefreak14 is offline
Old 20-10-2004, 02:52 PM   #23 (permalink)
NAV2k1 was the only good NAV ever ... i still have a cd of it, might install it sometime to see how it holds up these days
ujjwal is offline
Old 20-10-2004, 05:00 PM   #24 (permalink)
Laptoping
Sourabh's Avatar
Default no av for me
btw guys i installed norton2k5 systemworks today n it was as disappointing as always. same probs not again plz !!!
engine takes hell lotta time to boot up
install mcafee 9 yesterday it is not worth speaking too
earlier i used kasperesky for a week got rid of that too
now i feel no a/v is good
time for urself to get a lil bit concious over the net and copying data from cd,dvds
now i just use zone alrm pro 5 and webroot spy sweeper
Sourabh is offline
Old 20-10-2004, 07:06 PM   #25 (permalink)
gxsaurav
Posts: n/a
what U guys think is bloatware is not bloat but a feature, the NAV 2K5 boot time protection, which loads NAV when the system boots up, I have disabled it & my system boots in 12 Secs straight, it can also be because U have a lot of stuff loading during system startup, I only have 5 things,
It's just that if U don' use an always on internet connection like cable or broadband, then U should disable the boot time startup
Go to NAV options -> Auto Protect ->advanced
Uncheck, start NAV at system bootup, it's not bloat but a feature to protect from boot time virus
I have cable net, but the LAN connection by which it comes stays disabled if I m not using it, & with system startup net doesn't start
Kaspersky, soon, when more features will be added it will also become a bloat, just like NAV or Mcafee is rite now, while they were the best before
U must understand the difference between bloat & Feature, do U think they will make their product bloat just to loose reputation
Old 21-10-2004, 01:10 AM   #26 (permalink)
Another Brick in the Wall
drgrudge's Avatar
i have 256mb of RAM and still nav takes much of my ram...
i use nav coz i get updates to signitures, and most us use it...
drgrudge is offline
Old 21-10-2004, 01:15 AM   #27 (permalink)
i use kaspersky
pros-
-the updates are small
-the adware and spyware detection is great
-the virus detction rate is also very good
-you can really turn it off(not like nav where it still eats resources)
-cannot be ended through task manager
cons-
-the startup time increases by about 10 - 15 seconds after logging in
-cannot use it with the switch user feature of xp
-eats about 11mb ram
\"I was born INTELLIGENT
But EDUCATION ruined me!!!!\"
AMD 64 3200+(Winchester), MSI RS480M2-IL, 512*2 DDR400 Hynix, Segate 80 GB SATA, LG E700SH, i-benz with Intex PS (400 W)
technoteen is offline
Old 21-10-2004, 02:03 AM   #28 (permalink)
swatkat's Avatar
AVG and eTrust EZ AV rulez.
swatkat is offline
Old 21-10-2004, 09:25 AM   #29 (permalink)
gxsaurav
Posts: n/a
Hmm,NAC confusions
NAV can be compleately disabled if U want, here's how
1) Disable NAV Auto Protect from NAV->Options->Auto Protect
2) Stop the following services in the series
NAV Auto Protect, Symantec Core LC, Symantec Event Manager,Symantec Settings Manager, after that kill ccapp.exe
a catch is that even if U end task the ccapp.exe, while all the other things are on, NA Auto Protect is still on
Old 21-10-2004, 09:36 AM   #30 (permalink)
ice
Originally Posted by Indyan
AVG is better than mcaffe.
But symantec corporate isn't gr8.if u wanna try..Kav or NOD 32 shud b your choice.Extendia another option.
Nope, Symantec Corporate is Not bad, its really nice.
have u tried v9?
Edit : Just relaised its detection rates are 9% lower than KAV, btw how would kav run on a p4 2.40 with Winxp Sp2 and 128mb ram. [my gurls pc] ?
ice
ice is offline
- by Krow
