mmm...well, i can't see it being a software problem.....this won't hpn unless fedora core has wrecked ur BIOS n i can't see it doing tht....most likely hardware, just check ur connections.....i think the monitor's not detecting a signal, tht's why it turns on n then goes into power save mode...just chk the VGA cables, the gfx card if u hv one...take the gfx card out, clean the connector n put it back in...this solved it once when i had the same prob
The torquemaster rules.
