Old 18-10-2004, 11:54 PM   #1 (permalink)
bipin_hbk
Posts: n/a
Default HDD THRESHOLD EXCEEDED
I am having a hdd problem from few days
On startup it says "SMART THRESHOLD EXCEEDS"
Press F1 to continue
Is there any way i can get rid of this and get my perfect hdd back.
I know you can help b'coz u only got back my old hdd that had Bad sectors after your advice of low level formating it is working fine and perfect.
Help Me Pls.!!!!!!!!
Old 19-10-2004, 01:40 AM   #2 (permalink)
who ? when? where?
which os?
describe ur post... poori kahani?
Kshipra is offline
Old 19-10-2004, 03:44 AM   #3 (permalink)
i think u hav SMART enabled in the bios and seems that ur HDD is on the verge, so u keep gettin the warnin. me thinks its about to die...of course the pros will be here to aid u shortly...
...walking thru the twilight zone...there was no beginning...there is no...end...
www.baikunth.doornumber3.in
www.thefutureforest.com
FunkyB is offline
Old 19-10-2004, 07:59 AM   #4 (permalink)
ice
Ok...
U could try this.
1. A low level format
2. If the drive is in warranty, take it to the dealer and tell him the drive fails during the smart test
3. Try HDD regenerator/ Spin Rite 6.
Umm, cross ur fingers and hope for the best.
Btw install Drive Health or active smart , any one of them. on ur pc, and figure out which smart value exceeds the limit.
ice
ice is offline
Old 19-10-2004, 01:18 PM   #5 (permalink)
sujithtom's Avatar
Strange error. U must have edited the BIOS??
http://geeksbay.monzilla.info - My Tech Blog :)
sujithtom is offline
Old 20-10-2004, 11:15 PM   #6 (permalink)
Nops dear it's SMART comes only when ur disk is going to die, so go for
>>>>> CHANGE IT IF UNDER WARRANTY
or do any thing but guess it will dye soon so disable SMART
least that massege wouldn't show again.
can use spinrite 6.0 , but before go for one lower level format
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 21-10-2004, 07:40 AM   #7 (permalink)
Sorry, you cant do anything. You can remove that message by disabling SMART from the bios, but like demoninside said, its going to die, and soon too. Its best that you quickly save the data that you want from your drive and get it replaced.
Believe me, its not worth it to continue further with this drive.
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
[deXter] is offline
- by gohan89
