View Poll Results: DOES FORMATTING HARDDISKS REGULARLY HARMs IT IN ANY WAY ?
yes 6 22.22%
no 21 77.78%
Voters: 27. You may not vote on this poll
Old 16-06-2004, 09:17 PM   #1 (permalink)
AskRajesh
rajeshjsl's Avatar
Default DOES FORMATTING HARDDISKS REGULARLY HARMs IT IN ANY WAY ?
1)DESCRIPTION:-
POLL NOW FROM THE ABOVE TOPIC BECAUSE I WANT TO KNOW (I REGULAR FORMAT MY D DRIVE)
Q1:- DOES FORMATTING HARDDISKS REGULARLY HARMs IT IN ANY WAY ?
POLL OPTION-YES
POLL OPTION-NO
2)DESCRIPTION:-
HAVE YOU GOT HELP FROM WINXP'S HELP AND SUPPORT CENTER ANYTIME AND YOUR PROBLEM WAS SOLVED?
Q2:- HAD ANYTIME WINXP'S HELP AND SUPPORT CENTER SOLVED YOUR PROBLEM?
rajeshjsl is offline
Old 16-06-2004, 11:03 PM   #2 (permalink)
aadipa's Avatar
A1=> I format my hdd every 2-3 months, no problem for last 3years 6 months
A2=> I NEVER use windows' help
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 17-06-2004, 03:31 PM   #3 (permalink)
i keep formatting my hard disks
never got any error.
We are what and where we are because we have first imagined it...
--Donald Curtis
silly_kash is offline
Old 17-06-2004, 03:34 PM   #4 (permalink)
--Donald Curtis
Old 17-06-2004, 03:50 PM   #5 (permalink)
I usually format my C drive twice every month and full hard disk once every two months. I also take it to friends and everywhere.... etc etc etc
But it has no problem. Not even a single bad sector after 6 years of use. I
The Best Fencer is One who can beat his own SHADOW
shadowdm is offline
Old 17-06-2004, 04:28 PM   #6 (permalink)
Here is a question for all C-Formatters :
Why do you do it so frequently. What is the advantage. How do you guys manage the data/softeware stored on it
Thanks
Harsh
harmads is offline
Old 17-06-2004, 05:11 PM   #7 (permalink)
aadipa's Avatar
i install a lot of trialware/shareware and every program that i come across, so the hdd if full with unwanted dlls and registry entries, its better to reinstall OS than cleaning the system
as far as how i manage the data, NEVER KEEP YOUR IMPORTANT WORK ON YOUR MAIN DRIVE. i keep my files on second hdd and keep the partition hidden in explorer by using TweakUI
aadipa is offline
Old 17-06-2004, 05:16 PM   #8 (permalink)
aadipa's Avatar
also the big problem of fragmentation of free space, defragging helps but when u generally install/uninstall 1-2GBs of softwares every 2-3 days, its not that effective
aadipa is offline
Old 17-06-2004, 05:32 PM   #9 (permalink)
i format my c drive every month.after installing & uninstalling the drive becomes kind of slow.no harm done so far.
www.Oobertech.net
digen is offline
Old 17-06-2004, 07:49 PM   #10 (permalink)
JAK
What the Heck !
JAK's Avatar
I don't use the raw format command unless I badly need it.
I have used Drive Image2002 to create a image of my C: Drive. I created the image after installing all the software drivers etc, So the time when I feel my C: Drive is full of crap...I simply restore it from the image I have made ,stored in my Backup Partition(BTW I have made CD's of the image too just for backup) .So the system becomes as good as new....Also saves the time of Installin windows from scratch....The image gets restored say within 7mins...must faster then a scratch install
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
JAK is offline
Old 17-06-2004, 08:08 PM   #11 (permalink)
As far as i know nothing can happen if you format your harddisk regularly. this was even published in digit magazine.
Next message in %d minutes
cnu
http://feeds.feedburner.com/fslog.gif
cnukutti is offline
Old 17-06-2004, 08:09 PM   #12 (permalink)
and JAK that was a gr8 idea of yours.
cnu
cnukutti is offline
Old 17-06-2004, 09:15 PM   #13 (permalink)
nice idea jak .. hmm ... think ill give it a try even
No Mercy, No Limits.
theraven is offline
Old 17-06-2004, 10:22 PM   #14 (permalink)
Even i do the same.. just i use Ghost instead of drive Image..
I don't use the raw format command unless I badly need it. Wink
vswizard is offline
Old 18-06-2004, 12:46 AM   #15 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Me too using Ghost ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 18-06-2004, 12:59 AM   #16 (permalink)
Originally Posted by aadipa
....but when u generally install/uninstall 1-2GBs of softwares every 2-3 days....
1-2 GBs of software every 2-3 days is really a shocker mate.
What kind of software do you use?
svenkat83 is offline
Old 18-06-2004, 01:48 AM   #17 (permalink)
http://www.thinkdigit.com/forum/view...hp?p=6658#6658
Old 18-06-2004, 08:23 AM   #18 (permalink)
aadipa's Avatar
i just check if the software is working and review the softwares for my friends. i also download and install lots of freeware/shareware/trialware/nagware. so my registry is full of junk every couple of months
lately i have started using virtual pc for this but some software don't work on virtual pc, like games
aadipa is offline
Old 18-06-2004, 05:59 PM   #19 (permalink)
Let the music play.....
djmykey's Avatar
hey JAK pls can u forward the link to me ill try to do that pls man or can i just burn images of hdd from Nero coz it has such facility. If yes then how am i supposed to restore that image
djmykey is offline
Old 18-06-2004, 06:22 PM   #20 (permalink)
JAK
What the Heck !
JAK's Avatar
link to what...???? .........
and u cannot use Nero to create the image of ur system's drive(C drive) as it will not be able to read off files which r in use by windows...
So its better u use Drive Image or Ghost or
JAK is offline
Old 02-01-2007, 12:08 PM   #21 (permalink)
devgujar's Avatar
Thumbs up Re: DOES FORMATTING HARDDISKS REGULARLY HARMs IT IN ANY WAY ?
i format my hardisk twice a month no error yet
devgujar is offline
Old 02-01-2007, 12:21 PM   #22 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: DOES FORMATTING HARDDISKS REGULARLY HARMs IT IN ANY WAY ?
iv heard tht it does reduce the life of the hdd
http://beingmanan.com
iMav is offline
Old 02-01-2007, 12:24 PM   #23 (permalink)
gooby pls
Third Eye's Avatar
@devgujar: You have opened the old thread.
Reporting.....
Third Eye is offline
Old 02-01-2007, 12:27 PM   #24 (permalink)
iMav's Avatar
^^ didnt see the date its 3 yrs old
iMav is offline
Old 02-01-2007, 12:40 PM   #25 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
yeah man..this has been discussed n times...
NO PROBLEM IN FORMATTING THE HDD ANY NOS OF TIME
wizrulz is offline
Old 02-01-2007, 01:11 PM   #26 (permalink)
JhonCena's Avatar
I never formatted my hard disk coz there are a gbsss of softwares and songs so i cant back up them
my last format was on 25-August-2005
----------> http://www.blogofwebmasters.com/ <---------
WEBMASTERING TUTORIALS, ARTICLES AND MUCH MORE
JhonCena is offline
Old 02-01-2007, 01:14 PM   #27 (permalink)
The Researcher
After I started using Acronis True Image, I never felt any need to format my HDD.
Ramakrishnan is offline
Old 02-01-2007, 06:43 PM   #28 (permalink)
jal_desai's Avatar
nice.... really nice.. i mean it
TechExplorer.in
jal_desai is offline
