Old 25-12-2005, 01:19 AM   #1 (permalink)
__Virus__'s Avatar
Default C:\Program Files\Lavasoft\Ad-Aware SE Personal\Skins
Hi All,
Today I was scanning with my KAV persenal pro and everything went fine. As always, even today kaspersky dint scan this file "c:\Program Files\Lavasoft\Ad-Aware SE Personal\Skins\Ad-Aware SE default.ask" i dont suspect this file but my kav says its password protected and asks me to enter password which was given during installation of this file. I am sure ad-aware wont ask for any password during installation. Wondering what is this.
__Virus__ is offline
Old 25-12-2005, 02:39 AM   #2 (permalink)
yrana2002's Avatar
No password only if u install the personal version. Pro version has some security limitations but i guess its not the question of passwords, but simply serial numbers.
For the skins folder, it seems to be just a password protected archive. Nothing to worry about. If u want ur scans to be clean, simply put the folder in the ignore list or
Start Scan->Custom Scan-> Uncheck 'scan within archives'
Savvy!
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
Old 25-12-2005, 08:57 AM   #3 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Yup... Those skin files are password protected. Dont worry, they are clean...
kalpik is online now
Old 25-12-2005, 12:16 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
several files on several such applications are password protected, mence av or ani-spy scanners, cannot scne them. nothing to worry about.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 25-12-2005, 01:52 PM   #5 (permalink)
__Virus__'s Avatar
Yups done with no worries. One small question, why wud those files have passwords and which applications use those file. If ad-aware does, y wud it require password?
Old 25-12-2005, 02:24 PM   #6 (permalink)
anandk's Avatar
...secrets to protect, i guess...
Microsoft® MVP
anandk is offline
Old 27-12-2005, 02:04 AM   #7 (permalink)
__Virus__'s Avatar
Possible.
Old 28-11-2007, 05:21 PM   #8 (permalink)
Default Re: C:\Program Files\Lavasoft\Ad-Aware SE Personal\Skins
hi!) I finde a free version of Ad-Aware 2007
Earl1983 is offline
