Old 25-12-2005, 01:13 AM   #1 (permalink)
Default prob in sharing files on net....
hi all
two comps at my place are connected to the same hub.ping is working fine bet them.
but when i try to access the shared files of the other comp it asks me for the password even though there's none.
both have win xp+sp2. avast+ spybot.
windows internal firewall disabled
ips are 172.1.36.38 and 172.1.36.39
gateway and DNS of the settings are same.
presently i'm sharing files using DC++ but it still is a pain in the ar**.
is there a sftware using which file sharing can be done (with good speed)
both have onboard lan (100Mbps).
is ther a way to rectify this prob.....
TIA
manmay
peace
manmay is offline
Old 25-12-2005, 09:09 AM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Try borgchat...
kalpik is online now
Old 25-12-2005, 10:54 PM   #3 (permalink)
A good software to transfer files between two computers is PC-Mac-File Share Lite... The Lite version is free but has a file size limit (If I remember correctly, 10MB).
BTW, to access files on LAN in WinXP, you need to create an account with the other computer's username-password combination... This is because WinXP uses User-level sharing rights unlike Win98 which allowed simple Folder-based sharing.
Also, please confirm if you are using WinXP Home or WinXP Pro
Arun
sakumar79 is offline
Old 27-12-2005, 01:07 AM   #4 (permalink)
sakumar..thanks for eplying
i actually came across this software..
and even downloaded the lite ver...but didnt even get a chance to try it....
the problem got solved but going to create a small home or office network....
what i dont understand is that i had already done this procedure abt 2 times before with no result and the third time it worked.....
adding it to the list of mysteries of a comp.
anyway thanks guys for your help
manmay
peace
manmay is offline
