\"I\'ve Got A Great Ambition To Die Of Exhaustion Rather Than Boredom.\"
\"Where Would You Go When You Can\'t Forget The Past And You Don\'t Know The Future.\"
Download ieshwiz.exe it's 60 kb utility which integrates Customize wizard in right click of folder after installing you can change background wallpaper in windows xp
Hey i think.... It can be easily done when u get a copy the file named FOLDER.HTT though that in the program files folder.. in windows XP.... Else u can easily get a copy from uer friend's PC and copy on to any folder required... and edit the file with note pad to point to a PIC or uer choice in uer PC...
