Well which OS are you using. If it's XP then try searching web for its driver through Hardware Update Wizard.
Is your webcam detected by XP on pluging it. If yes then It might have detected it as generic camera or other. try to find out in Device Manager. You might notice scanner and camera wizard in program->Accessories. Now open it to see if it has detected the webcam or not.
Try out these steps. Hope it might help. I thing more, Yahoo Messenger automatically detects webcam. Try installing YM and see if it detects it or not. Even you could use MSN Messenger, instead YM.
