Old 23-12-2005, 10:22 PM   #1 (permalink)
MenTaLLyMenTaL's Avatar
Default Which AV will best suit my needs?
I've read the Reviews, but am not able to decide which one to use.
What I want in the AV:
1) Obviuosly a good protection from viruses, trojans, spyware etc
2) Least memory intensive
3) Should give option to disable it from a normal User account also (in XP)
4) Should give a detailed name of a malware when found (I hate the name Avast shows - just like Trojano/123)
5) Should give option to exclude some folders from scanning
6) Updates
7) Should have a onAcces scanner
8) Don't need email scanner
9) May or maynot be freeware
I've tried
1) Mcafee 9 (only for a few minutes) - Very memory intensive
2) Panda Personal - Slowed down startup, didnt look satisfactory
3) Avast free - Nice but not good in detecting and not satisfactory virus names
4) BitDefender - I liked very much, not much memory intensive. Only thing for which i removed it yday is it freezes Opera when its loading a page and i cant do with opera freezing every now and then
5) AntiVir - Temporarily installed till i get satisfactory response from here, but i find it very less memory intensive. Extremely happy with it, but i dont know how good its detection is. I tried testing it with EICAR, it detected .com while downloading, but didnt detect .zip and .txt.
Dont be reluctant to do MenTaL work.
MenTaLLyMenTaL is offline
Old 23-12-2005, 10:48 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
this has been posted many time
please search
moreover ,
i suggest goin for Norton-2006
coz arguably nortan is the best
albiet the system resources anamoly
but it too has been cleared up in Nortan-2006
vijay_7287 is offline
Old 23-12-2005, 11:07 PM   #3 (permalink)
try NOD32..... i started using it a month or so back and it hasnt given me any problems as yet... very good detection, low memory usage, small update sizes. used to have norton 2005, totally updated, but NOD has detected and removed quite a few trojans from my installation which norton didnt even detect.
kikass is offline
Old 23-12-2005, 11:15 PM   #4 (permalink)
You have not tried the best antivirus software!!
You MUST try these two
1)KASPERSKY ANTIVIRUS 2006 & ANTI HACKER(firewall)
2)PC-CILLIN INTERNET SECURITY 2006
Pc-cillin has spyware detection & fraud detection(like in IE 7 beta) and lots of other features
both as as good if not better than Norton in terms of protection , they dont eat up your system resources either
Dont go for ANY SYMANTEC PRODUCT they just got lucky so many people brought their product
Sajeev is offline
Old 23-12-2005, 11:16 PM   #5 (permalink)
try Ewido, i have been using it for 2 months.
it also scans for malwares and registry changes.
ashnik is offline
Old 23-12-2005, 11:16 PM   #6 (permalink)
__Virus__'s Avatar
"IF" you are or wud like to use Norton, I recommend you to go for Norton corporate versions. Oh my it consumes not much than 350 k of memory.
BTW is it true with Norton getting low on system resources in version 2006 ?
__Virus__ is offline
Old 24-12-2005, 01:13 AM   #7 (permalink)
About Norton, i myself have seen it cannot detect some trojans when packed a little (I tried at Yahoo Mail for testing). And when i had NAV 2004, it ate resources. So if its gonna become a better detector and eat low resources in 2006, i'll get it.
But after reading the reviews in other section, I'll try NOD32 first coz low use of resources is my first priority.
Old 24-12-2005, 08:30 AM   #8 (permalink)
I have been using Avast for more than one year now, but along with Zone Alarm, Spybot, AdAware and Spywareblaster and now MS Antispyware also. Earlier it was Win 98 and now Win XP SPII. Never had any problem. It is low on usage of resources, especally when compared to Norton which I was using earlier for many years. And it is updted almost daily and sometimes more than once daily. And it is free.
V.Prem Kumar
V.Prem Kumar
janitha is offline
Old 24-12-2005, 09:03 AM   #9 (permalink)
Rebooting
Choto Cheeta's Avatar
i would say go for Kaspersky AntiVirus Personal Pro 5.0
the 2006 is still in beta stage... & it has had its problem... many problem is still yet to be solve... lots of bug is still their to be removed... imfact they delayed its release... check the KAV official forum
i suggest those who considering to go for 2006 version of KAV to waut a little bit... the KAV 5.0 is still the best even every other AVS company have brought 2006 new version... up2date KAV 5.0 still the best...
but the KAV is a little resource hungry... untill u scan the whole HDD once...
Choto Cheeta is offline
Old 24-12-2005, 09:55 AM   #10 (permalink)
Kspersky Anti Virus shall fulfill ur needs to the T.....I have heard that NAV 2006 is no all that resource hungry, but I am paranoid about it & will not recommend it to anyone....
You may also try Quick Heal.....It is damn fast...very low on resources & its detection rate is very good.....The only con....Far too many false alarms....
HK
h_kunte is offline
Old 24-12-2005, 05:09 PM   #11 (permalink)
I think i'll sick to NOD32 now that i have it installed. I'll try QuickHeal also later.
Old 24-12-2005, 05:36 PM   #12 (permalink)
invisible
Posts: n/a
suggest only one good AV.
everyone is saying their own antivirus is the best like norton,kasper,jumbo,panda,nod,avg,qucikdeal,bit,fu t,mandra,pcclean,........ wtf?
Old 24-12-2005, 05:38 PM   #13 (permalink)
invisible
Posts: n/a
Hey why dont you try Zonealarm antivirus 5(not 6)
Old 24-12-2005, 05:38 PM   #14 (permalink)
Commander in Chief
QwertyManiac's Avatar
@invisible - ITs still a myth as to which is the best Anti... it takes time deciding..
QwertyManiac is offline
Old 24-12-2005, 05:41 PM   #15 (permalink)
invisible
Posts: n/a
zonealarm antivirus 5 is the best with no bugs,no system slowness,very very good antivirus protection(even while visiting harmful sites like freeserials),best firewall
dont go for 6 version too buggy and slows the system to an extent
Old 24-12-2005, 05:43 PM   #16 (permalink)
Commander in Chief
Yes and u might like to add one more thing - "Does nothing, not even warns/disables ur virii, purely unobtrusive and useless, all for jus $435739457 only"
Harsh J
www.harshj.com
Old 24-12-2005, 05:46 PM   #17 (permalink)
invisible
Posts: n/a
wtf
i used norton before but wtf it didnt detect many worms while visiting crack sites
but with ZA5 it simply superb
dont post such **** comments without testing it
Old 24-12-2005, 07:55 PM   #18 (permalink)
Default Re: Which AV will best suit my needs?
I m also using it and I m fond of this free av.
I suggest just stick with it..
Computer.
Whats that.
Is it some kind of frog.. turr turr turrr...
con_tester is offline
Old 24-12-2005, 08:13 PM   #19 (permalink)
invisible
Posts: n/a
mental test this one
http://rapidshare.de/files/8281319/z...4_000.exe.html
this comes with AV + FW .FW might be confusing for u in the initial state but its simple.
Old 24-12-2005, 10:38 PM   #20 (permalink)
For ZA AV -
System Requirements:
Windows 98SE/ME/2000 Pro/XP. Pentium III 450 MHz or higher. 50MB of available hard disk space. Internet access. Minimum system RAM: 48MB (98SE/ME), 64MB (2000 Pro), 128MB (XP). More Info
Other AVs dont require so much which means that ZA will be more resource hungry than them.
Right now i am quite satisfied with NOD32 and next to it is AntiVir. I am just not sure of their virus detection capabilities. If they are good in detecting, then that's my final.
Old 24-12-2005, 10:49 PM   #21 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Yeah, if you want a good and nice and light AV, go for NOD32. Otherwise Kaspersky could be a second choice. Dont even look for a third one....
For independant AV reviews, check http://www.av-comparatives.org
And those of you recommending ZA, its using VET engine. Not that good, if you ask me.
Nod32 has the *best* heuristics in the AV industry check pro-active tests at http://www.av-comparatives.org
Kaspersky has the best signatures...
The choice is yours... But one thing i can say confidently, no other AV can even TOUCH these two AVs..
kalpik is online now
Old 24-12-2005, 11:43 PM   #22 (permalink)
Thanks for thst site, it makes NOD32 final.
Old 25-12-2005, 01:08 AM   #23 (permalink)
__Virus__'s Avatar
i go with kalpik. One prob, if you could explain a bti more about "Nod32 has the *best* heuristics " i would be thankful. As i use kaspersky personal PRO ( took me months to get key ) i am COMPLETELY satisfied with it
Old 25-12-2005, 03:24 AM   #24 (permalink)
Biplav's Avatar
za av is useless.
i just installed it and sooner than i expected: removed it.
try this:
http://www.misec.net/products/TrojanSimulator.zip
is a trojan simulator:dont worry it wont harm ur pc.
its for testing ur AV's strenght.
i had ZA and yes it detected it but not as a Trojan or virus but as an application trying to launch itself at the start of the computer everytime like yahoo msngr, deamon tools,nero check, za itself .
It failed in detecting it as a trojan.
now i installed nod32 and it wont even allow me to download the file.
Nod32 is by far the best option if u want best security without compromising on the Ram.
Biplav is offline
Old 25-12-2005, 08:54 AM   #25 (permalink)
kalpik's Avatar
Heuristics is a technology which identifies new and unknown viruses. Most AV's require signatures or definitons to detect viruses. Even NOD32 does, but it has excellent heuristics. Suppose there is a new virus outbreak. The AV guys identify the virus and release signatures for it. Even though Kaspersky releases signatures almost every hour, even then you may not get those signatures for the latest virus before 1 or 2 hours. You are at a risk for those 2 hours... Heuristics although identify that virus without the need for signatures... Thats how it gives zero hour protection. NOD32 identified all those mytoob, zotob and sober varients without signatures...
Hope i explained it well! Actually i've done a lot of research on AV's and Firewalls... If any help needed, please ask!
Old 25-12-2005, 11:52 AM   #26 (permalink)
Distinguished Member
anandk's Avatar
Originally Posted by Biplav
za av is useless.
try this:
i.
nice link biplav. i use zass, and have not been infected. but u r right, it did not detect it. i also have avast and avg as my secondary av. they too did not detect it. only trojanhunter and ewido detected it as 'the test trojansimulator file'. this led me to think that perhaps the av scanners r smarter than v think, and they know its the test trojan, and threfore do not want to identi5 it as one. nod32 must have detected it on its heurisics strength.
i too agree with most views above:
kav for definations strength. even bitdefender is good !
nod32 for arguably the best heuristics.
ultimately, MenTaLLyMenTaL, u will have totry a few b4 u settle on one !
i tried almost all except norman, pclin among the top ones;
i prefer to use the triple defense layered zass.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 25-12-2005, 12:43 PM   #27 (permalink)
invisible
Posts: n/a
za av is useless.
try this:
u mighe have used ZA6 version
tell me which antivirus is detecting this demo trojan?
Old 25-12-2005, 12:45 PM   #28 (permalink)
invisible
Posts: n/a
For ZA AV -
this is for version 6 not for 5
Old 25-12-2005, 03:44 PM   #29 (permalink)
kalpik's Avatar
za av is useless.
try this:
none?
Old 25-12-2005, 04:57 PM   #30 (permalink)
NOD32 doesnt give exact name of a malware. Mostly it gives NewHeur_PE. I think I'll switch to AntiVir again. Bitdefender is what I like very much but only thing that stops me from using it is it interferes with Opera.
