Old 18-10-2004, 03:31 PM   #1 (permalink)
Default Info u all wanted
Guys, I have some old CDs which have scratch. They do not run. Should I wash them with soap?(as suggested in a post on this forum). Plz. help me!!!
Also, should I opt for Tata Indicom internet connection or Data Infosys connection? What r their tarrifs??
Thanx
prabhatmohit is offline
Old 18-10-2004, 05:33 PM   #2 (permalink)
The Photoshop Guy
cooljeba's Avatar
hi prabaht
Those cd washing technique should be used only when u ahve no option left
There are some fluids available in the market which fills up the scratches. BTW they can't fill up deep scratch...
Regarding ur 2nd query
i use tataindicom wireless internet it's kinda ok but the problem is ur phone remains engaged when u using it. bandwidth wise they are equal to a 64 kbps cable net ( The modem is 115 kbps though ). If u are planning for heavy d/l then it's a strict no no!
..:: peace ::..
Jeba
cooljeba is offline
Old 18-10-2004, 08:19 PM   #3 (permalink)
busyanuj's Avatar
Default Re: Info u all wanted
you can try using Alcohol 120% (software) to read those scratched discs.
Using the cleaning fluid should be the last option, though it is unlikely to help.
busyanuj is offline
Old 18-10-2004, 09:26 PM   #4 (permalink)
use isobuster to extract files and use them
bhare ka tattoo is offline
Old 18-10-2004, 09:28 PM   #5 (permalink)
and dont wash ur cds unless absolutely necessary
Old 19-10-2004, 01:31 AM   #6 (permalink)
alcohol's the solution..try it and be amazed
Attack life, it\'s going to kill you anyway.
walking-techie is offline
