Old 23-12-2005, 02:11 PM   #1 (permalink)
Default deactivate "show hidden folders"
how can i deactivate "show hidden folders" from the 'Folder options'???
joshy is offline
Old 23-12-2005, 02:23 PM   #2 (permalink)
My Computer>Tools>Folder Options>View>
Scroll down and select Do not show hidden files and folders.
Massacre is offline
Old 23-12-2005, 03:32 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
He didnt ask how to enable/disable.. but how to de-activate... that is No one else than him can switch that option...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 23-12-2005, 06:33 PM   #4 (permalink)
__Virus__'s Avatar
I have done this simple trick to achieve this long back. Smart asses may still be able to bypass this. Here is what to do
Go to Start > Run > type "Regedit" without quotes, this brings up registry editor. Click on Hkey_Local_Machine and Press Ctrl+f then type
Hit enter and the exact search result will be in some location like
Hkey_Users\s bla bla bla bla\Microsoft\windows\ShellNoRoam\MUICache"
Edit Three keys here:
1. @shell32.dll,-30499 > Hidden files and folders
2. @shell32.dll,-30500 > Show hidden files and folders
3. @shell32.dll,-30501 > Do not show hidden files and folders
Dont edit anything starting from @ till number ending. Edit under "Date" tab. Rename it to watever you like. Name it completely different Like " Redhat Linux" "Macintosh" "Apple Ipod" but do remember
Dont know anyother way
Edit: Screen Shot
__Virus__ is offline
Old 23-12-2005, 07:39 PM   #5 (permalink)
Dipen01's Avatar
Nice one..man...
BTW say..can we disable the option itself..??
I love walking in Rain ,because no-one knows i am Crying :|
Dipen01 is offline
Old 23-12-2005, 08:03 PM   #6 (permalink)
__Virus__'s Avatar
Delete the specified entries. Oh but wont be able to view the files Ur self.
Old 23-12-2005, 09:11 PM   #7 (permalink)
puja399's Avatar
@__Virus__
Nice trick !!! Thanks for the tip.
puja399 is offline
Old 23-12-2005, 09:16 PM   #8 (permalink)
__Virus__'s Avatar
Most welcome
