Old 23-12-2005, 02:09 PM   #1 (permalink)
Default how do i SLEEP ?
how can you set your computer for SLEEP as in television????
joshy is offline
Old 23-12-2005, 02:17 PM   #2 (permalink)
bala4digit's Avatar
You Mean shutdown after some specific time...You can do that by simply programming your windows task manager!
\"I\'ve Got A Great Ambition To Die Of Exhaustion Rather Than Boredom.\"
\"Where Would You Go When You Can\'t Forget The Past And You Don\'t Know The Future.\"
bala4digit is offline
Old 23-12-2005, 02:24 PM   #3 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
^^ im quite sure you meant task sheduler instead of task manager!
kalpik is online now
Old 23-12-2005, 02:34 PM   #4 (permalink)
bala4digit's Avatar
HEHEE...yeah man damn sorry !!!...kalpik is right....!!
Old 23-12-2005, 02:35 PM   #5 (permalink)
siriusb's Avatar
Most utility suites (tuneup/mindsoft) come with such a scheduling utility. If u have one of them, you can use it.
Or you can use this free one.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 23-12-2005, 03:42 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
For actually Sleep... he mite be asking about Hibernation perhaps
Harsh J
www.harshj.com
QwertyManiac is offline
