Old 23-12-2005, 01:48 PM   #1 (permalink)
Default cd writing permission
how will an administrator give cd writing(nero express) permission to a limited user account in windows xp
joshy is offline
Old 23-12-2005, 01:49 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Google for "nero burning rights"
kalpik is online now
Old 24-12-2005, 10:15 PM   #3 (permalink)
q3_abhi's Avatar
There is an option for "Nero Burning Rights" in Control Panel ( If u have Nero 7)
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 24-12-2005, 10:26 PM   #4 (permalink)
In windows XP:
Disable CD Burning
Open your registry and find or create the key below.
Create a new DWORD value, or modify the existing value, called "NoCDBurning" and set it according to the value data below.
Exit your registry, you may need to restart or log out of Windows for the change to take effect.
Registry Settings User Key: [HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\
Explorer]
System Key: [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Policies\
Explorer]
Value Name: NoCDBurning
Data Type: REG_DWORD (DWORD Value)
Value Data: (0 = Allow CDR, 1 = Disable CDR)
Disclaimer: Modifying the registry can cause serious problems that may require you to reinstall your operating system. We cannot guarantee that problems resulting from modifications to the registry can be solved. Use the information provided at your own risk.
Allow limited users access to CD Burning:
To allow Limited User's to burn CD's, click Start/Run/Regedit and go to:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
Look in the right pane for AllocateDASD and double click the entry. Set the value to 2.
On PRO, this is exposed in Local Security Policy under Security Settings\Local Policies\Security Options.
"Devices: Allowed to format and eject removable media"
For XP Pro, you can do this by clicking Start, Run and entering SECPOL.MSC
Go to Local Policies, Security Options, look in the right pane for Devices: Allowed to Format and eject removable media. Set this option to Administrators and Interactive Users.
rajas is offline
