I can't open .mov files in Quicktime. It shows an error. I have put a screenshot below... When I open in Real Player it just showes a blank white screen. P.S No virus, latest version of both players...
http://geeksbay.monzilla.info - My Tech Blog :)
I uninstalled it and then re-installed. No change. I can see thos in Win 98 but doesnot works in XP. The colour of start menu becomes terrible. I will post its screenshot soon..
- have u updated the display adapter drivers for xp ? do u have integrated graphics or nvidia .
- try updating the drivers and choosing 24 color or 32 color option
- do u have divx and flash plugins installed ? both come with the dig cd/dvd i think
- check xp device manager , if u have an error with display adapter .
I exported a presentation from Keynote to a movie, but when I came to play it on a Windows XP computer with QuickTime 6.5 installed, I got an error -8992 message. There was sound, but no picture.
After messing around for a bit, turns out disabling Video Acceleration in the QuickTime settings solved the problem. Try disabling DirectShow first, then DirectDraw, then just turn off all the Video Acceleration options.
