Old 22-12-2005, 09:05 PM   #1 (permalink)
nil_3's Avatar
Default Movie VCD---How they are created?
How the original movie VCDs are created? Is it that first the film is scanned and then the file is converted to VCD? Or any other procedure?
Which softwares are employed in preparation of those original (and NOT PIRATED) movie VCDs that are released by the movie production houses?
I am asking this question because whenever I make VCD from footage taken from my handycam, it loses clarity(though i get excellent clarity by making DVD). Original movie VCDs are also of excellent picture clarity. How it becomes possible?
nil_3 is offline
Old 22-12-2005, 09:54 PM   #2 (permalink)
dIgItaL_BrAt's Avatar
One of the most popular softwares used for movie authoring is Sonic Foundry's (now Sony's) Vegas.It gives you total control over the authoring process.The movie is first digitized from it's original print and then converted to DVD/VCD.
dIgItaL_BrAt is offline
Old 22-12-2005, 10:21 PM   #3 (permalink)
nil_3's Avatar
Well, but wish to hear from other TECHIES.
nil_3 is offline
Old 22-12-2005, 10:23 PM   #4 (permalink)
__Virus__'s Avatar
Mean mean atleast thank brat for small but timely help
__Virus__ is offline
Old 23-12-2005, 03:08 AM   #5 (permalink)
Rubik's Uncle!!
Charan's Avatar
hi nil_3 a tip for u. You can create svcd insted of vcd for better quality. vcd's are mpeg1 but svcd and DVD's are mpeg2 which gives more clarity
and quality . I create only svcd & DVD's. i hate VCD . maybe u can try KVCD format. i still havent made those KVCD's as i cannot find nessary tools,but ill keep trying
charan
Charan is online now
Old 23-12-2005, 06:01 AM   #6 (permalink)
nil_3's Avatar
@ dIgItaL_BrAt & __Virus__.
Thanks BrAt for your information and thanks __Virus__ to remind me.
@ charangk
What is KVCD? Sorry, but I hav'nt heard of this?
nil_3 is offline
Old 23-12-2005, 10:36 AM   #7 (permalink)
puja399's Avatar
Default Re: Movie VCD---How they are created?
Commercial movies are shot with high quality cameras giving near perfection colors, but the handycams u r taking about give low quality images, hence the difference. Moreover, commercial movie shots use calculated lighting etc. which gives better result. If u can use even a better qualilty 3CCD camcorder with spotlight, u can get better result that what u r getting now.
puja399 is offline
Old 23-12-2005, 11:12 AM   #8 (permalink)
I am asking this question because whenever I make VCD from footage taken from my handycam, it loses clarity(though i get excellent clarity by making DVD). Original movie VCDs are also of excellent picture clarity. How it becomes possible?[/quote]
Movies are made from cameras whose quality cannot be matched by small handycams hence movie VCDs are very clear and
home videos on VCD are not as clear as a movie VCDs, but one can make high quality DIVX or Video DVD from Raw Video from the Tape
Do you have a DV cam and do you use i-link(IEEE1394 firewire) to transfer the video to transfer video to your PC ?
I have a SONY Digital8 handycam and am not able to transfer raw video using i-link port which i have on my PCI slot
USB transfer is useless as video quality diminishes
My camera is not detected while it is connected through i-link
Sajeev is offline
Old 23-12-2005, 12:50 PM   #9 (permalink)
Can anyone tell how these films are digitized from film strips to digital format.
There is a very fine line between genius and insanity. I have erased this line.
freezer is offline
Old 23-12-2005, 01:20 PM   #10 (permalink)
Quality of the VCD movie is dependent on the "motion search precision" of the encoder. Most commecrial production houses will use hardware encoders for both MPEG1 (VCD) and MPEG2 (DVD) video encoding.
To get good quality VCD encodes (using a software encoder on your home PC), try this -
Get yourself a copy of Tsunami MPEG (TMPEG) encoder. http://www.tmpgenc.net/e_download.html <-- free for MPEG1
Open your captured DV file (hint: use http://windv.mourek.cz/ for Dv capture) and encode using the default (PAL) VCD profile, BUT after changing the "motion search precision" to "high quality". You might have to load the "unlock.mcf" profile to change advanced settings. Search for TMPEG guides at www.videohelp.com
IMPORTANT: Author and burn the output using a VCD structure but DO NOT re-encode (Nero tries to re-encode, avoid).
Use http://www.vcdeasy.org/ instead to author and burn. It's not free.
OR get VCDImager http://www.afterdawn.com/software/vi.../vcdimager.cfm
and get the GUI from here http://www.videohelp.com/vcdimagergui.htm Put it in the same folder as VCDImager.
Hope this helped,
Keith
Keith Sebastian is offline
Old 23-12-2005, 06:59 PM   #11 (permalink)
Rubik's Uncle!!
Charan's Avatar
@nil_3
What is KVCD?
"K Video Compression Dynamics"
KVCD is a modification to the standard MPEG-1 and MPEG-2 GOP structure and Quantization Matrix. It enables you to create over 120 minutes of near DVD quality video, depending on your material, on a single 80 minute CD-R/CD-RW. We have published these specifications as KVCDx3, our official resolution, which produce 528x480 (NTSC) and 528x576 (PAL) MPEG-1 variable bit rate video, from 64Kbps to 3,000Kbps. Using a resolution of 352x240 (NTSC) or 352x288 (PAL), it's possible to encode video up to ~360 minutes of near VCD quality on a single 80 minute CD-R. The mpeg files created will play back in most modern standalone DVD players. You must burn the KVCD MPEG files as non-standard VCD or non-standard SVCD (depends on your player) with Nero or VCDEasy.
Using KVCD parameters to create DVDs (KDVD), will enable you to create 100% DVD compliant MPEG-2 streams, capable of playing on any standard DVD player. This will allow you to put up to about 6 hours Full D-1 720x480 on one DVD, or about 10 hours at Half D-1 352x480.
source: www.kvcd.net
Old 24-12-2005, 02:04 PM   #12 (permalink)
thanks for the discussion.
Searching for more on net about this topic
abhinav is offline
Old 25-12-2005, 08:27 AM   #13 (permalink)
nil_3's Avatar
@ abhinav
Please do.
nil_3 is offline
