Old 22-12-2005, 08:14 PM   #1 (permalink)
Traceur
zegulas's Avatar
Default No one in this universe can make a ' con ' folder!!!
Hey I have heard that no one can make a folder named con in windows, dont know abt linuxs.
And also heard that Bill Gates has announced some heavy money for the one who does it!!!
Parkour: A journey started by two & followed by many...
zegulas is offline
Old 22-12-2005, 08:32 PM   #2 (permalink)
Walking, since 2004.
mail2and's Avatar
i live in this universe and i can make a folder named con
Mumbai, I miss you. :(
mail2and is offline
Old 22-12-2005, 08:33 PM   #3 (permalink)
Laptoping
Sourabh's Avatar
Unlocked the thread. The old thread has been lost due to the prunning of the In General Section. Thanks to zegulas for pointing that out.
Sourabh is offline
Old 22-12-2005, 08:50 PM   #4 (permalink)
Traceur
zegulas's Avatar
ok dude then tell us how to do it! 8)
zegulas is offline
Old 22-12-2005, 08:53 PM   #5 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Same here! Even i can make a con folder!
goto command prompt, type in prompt "mkdir \\.\c:\con"
to delete folder, "rmdir \\.\c:\con"
kalpik is online now
Old 22-12-2005, 09:29 PM   #6 (permalink)
Even I know the last one method...
Now Where I can get money from billy...
Computer.
Whats that.
Is it some kind of frog.. turr turr turrr...
con_tester is offline
Old 22-12-2005, 10:15 PM   #7 (permalink)
Traceur
zegulas's Avatar
ok, now i know u guys can make a folder named CON, but wats the logic behind all this: :roll:
zegulas is offline
Old 22-12-2005, 10:16 PM   #8 (permalink)
__Virus__'s Avatar
Default Re: No one in this universe can make a ' con ' folder!!!
Over Excited
This is digit and techo minds reside in here
__Virus__ is offline
Old 22-12-2005, 10:20 PM   #9 (permalink)
kalpik's Avatar
YOU started the topic!!! You tell us!!
Old 22-12-2005, 10:21 PM   #10 (permalink)
__Virus__'s Avatar
Old 22-12-2005, 10:28 PM   #11 (permalink)
Traceur
zegulas's Avatar
I think u guys dont get me, wat i mean to say is that, why cant we just make a folder named con (using normal method, right click and make new folder and name it)???
zegulas is offline
Old 22-12-2005, 10:28 PM   #12 (permalink)
kalpik's Avatar
Ok, actually if you really need information about why its not allowed, here goes... Actually, there used to be some reserved names in DOS, because they were commands or device names in DOS. (CON refers to console, or the keyboard). Some other reserved names: CON, AUX, COM1, COM2, COM3, COM4, LPT1, LPT2, LPT3, PRN, NUL.
And if u wanna know about how the command i gave overcomes this problem, check here: http://en.wikipedia.org/wiki/Univers...ing_Convention
Old 23-12-2005, 12:07 AM   #13 (permalink)
Gud enlightenment 2 me
adi87 is offline
Old 23-12-2005, 01:04 AM   #14 (permalink)
yea... that's just a simple thing.... someone must have fooled you.... saying... Gates will award to anyone who..... that's funny isn't it???
Ravi.
http://ravishchandra.blogspot.com/
Ravi+ish is offline
Old 23-12-2005, 09:04 AM   #15 (permalink)
kalpik's Avatar
@adi87: My pleasure!
Old 23-12-2005, 12:37 PM   #16 (permalink)
tuxfan's Avatar
con stands for console i.e. display. It is an existing device in Windows. That is why you can't make it with normal methods.
Try this command in command prompt
copy con myfile.txt
Type a few things and hit F6 or Ctrl+Z. All that you typed will become the content of myfile.txt. This is the usual copy command whose syntax is
copy file1 file2
Se here, file1 is what is on console i.e. con
tuxfan is offline
Old 23-12-2005, 01:22 PM   #17 (permalink)
mail2and's Avatar
From Applications/Utilities/Terminal "mkdir con"
Otherwise, right click.. click on "new folder" and name it
mail2and is offline
Old 23-12-2005, 01:51 PM   #18 (permalink)
kalpik's Avatar
^^ renaming the new folder does not work...
Old 23-12-2005, 02:17 PM   #19 (permalink)
left this forum longback
praka123's Avatar
You started the same old topic the world had discussed,,and bored....even in digit as mod tolds....so now another question also someone will ask like
"No one in this universe can make a ' LPT ' folder!!!"
praka123 is offline
Old 24-12-2005, 12:38 AM   #20 (permalink)
aadipa's Avatar
It works.........
on Mac
aadipa is offline
Old 06-02-2006, 08:15 PM   #21 (permalink)
ha ha
here is the way baby !!!!!
STEP1: goto command prompt
STEP2: type in prompt e:\> "mkdir \\.\e:\con"
STEP3: verify by typing "dir \\.\e:\con"
STEP4: delete the file or folder "rmdir \\.\e:\con"
[img]http://img78.imageshack.us/img78/2920/bluebar9et.gif[/img]
Regards ,
Muthusrinivasan
[img]http://img229.imageshack.us/img229/3883/20fl.gif[/img]
muthusrinivasan is offline
Old 07-02-2006, 10:31 AM   #22 (permalink)
ramprasad's Avatar
I was able to make the folder named LPT in Windows directly
ramprasad is offline
Old 07-02-2006, 02:34 PM   #23 (permalink)
Default Reply
@Ramprasad
Hey Ramu Prakash was just joking, u failed to understand it.
@ Zegulas
U know 1 thing it was an Indian who discovered it ( CON CANT BE CREATED).
Andyiz is offline
Old 20-02-2006, 12:58 PM   #24 (permalink)
Default reply
Originally Posted by muthusrinivasan
ha ha
i couldnt get it, can xplain it clearly???
Andyiz is offline
Old 30-06-2008, 01:27 PM   #25 (permalink)
Here's another method I thought I'd drop by.
Right click>New>Folder
type: con
and then select the ALT key
and at the same time on the NUMBERPAD type 255 (With the ALT key selected)
And there is con!!!
Have fun!!!
no need for cmd!!!
Now does anyone know how to delete the folder? It's on the desktop for me and I couldn't use cmd it just wouldn't work
computer41 is offline
Old 30-06-2008, 01:38 PM   #26 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
nice idea bumping a 2 year old thread for a first post
nyway, I just right click, new folder and name it as con. 100% no issues.
this thread title is just a FUD.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 30-06-2008, 03:33 PM   #27 (permalink)
evewin89's Avatar
i read it somewhere that this happens because of UNC.
1 more thing u can also try out with other file names like prn,com1 to com9,etc
Evil Lives 4ever......
evewin89 is offline
Old 01-07-2008, 04:14 PM   #28 (permalink)
The Smaller Bang
all work. no issues.
Old 01-07-2008, 05:06 PM   #29 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Magic - Windows is NOT 'CON'NING Me
Have a look here B)
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 01-07-2008, 05:53 PM   #30 (permalink)
kalpik's Avatar
computer41: Your method actually will have a "space" after con.. so it will be "con " and not "con" so that doesn't count.
Metalhead: Renaming does not work on windows.
Anyway.. this has been discussed to death many times.
Topic locked.
- by gohan89
