22-12-2005, 05:50 PM
Exe extractor
Hi All,
I have this sometheme.exe and since I am on limited account I don't have permission to install the exe. Is there any tool to extract the content of the executable. I have googled and tried all possible resolutions, sadly no help. Any help will be greatly appreciated. One more question. May I get direct .theme file from any site as I mentioned I cant install anything on here.
Regards,
Virus.
22-12-2005, 06:30 PM
use winrar
22-12-2005, 06:34 PM
100% sure winrar wont open it. Did once as per ur instructions but:
The archive is either unknown format or damaged.
22-12-2005, 07:04 PM
In Pursuit of "Happyness"
Try executing it on another PC, and then copy the theme!
22-12-2005, 07:06 PM
I very well know that dood. We all on here have limited accounts and hence cant extract or install it.
22-12-2005, 07:08 PM
Well! Send the file to me, ill extract it and send the theme to you!  What more can i do!! Sorry, if winrar is not extracting it, nothing will.
22-12-2005, 07:12 PM
wo hoooo thanks so much...wonder can I send every theme
http://www.themexp.org/theme_control...ona+is+now.zip
Thanks again
*Searches further for extractor*
22-12-2005, 07:14 PM
Im downloading the file. Will analyse it too, maybe i can help you to find a program to extract it!
22-12-2005, 07:19 PM
Thanks a lot dude!!!
Look what kaspersky found in the file!! Aaj kal bhalaai ka zamaana hi nahi raha!
22-12-2005, 07:29 PM
...Aaj kal bhalaai ka zamaana hi nahi raha!
... rightly said...
22-12-2005, 07:30 PM
That's direct link to themexp.org
Kas might Prolly have detected it as it the theme installs some kind of toolbar which can be uninstalled from control panel
22-12-2005, 07:40 PM
Yes, i tested the file, actually it contains active shopper. Thats actually a pretty bad adware. I managed to extract the file too. Use: http://www.pediy.com/tools/unpack/Wise/WUN.rar
By the way, i would not suggest installing it.
22-12-2005, 07:48 PM
You made my life easier with that..... Been searching for long long time. Thanks a lot
Affirmative. * There goes the download into bin*
22-12-2005, 07:50 PM
Hehe no prblems man! Just dont send me a virus next time!!!
Just Kidding!
Cheers!
22-12-2005, 09:52 PM
Just Kidding!
Cheers!
That's what I am
Search this Thread |
