Old 22-12-2005, 09:47 AM   #1 (permalink)
Distinguished Member
anandk's Avatar
Default 'size' vs. 'size on disk' ???
in 'windows properties' of a xp folder, the figures for
size, and
size on disk
are different.
what is the difference betwn the 2 ?
eg, my c/windows shows :roll:
size as 4.70 gb but
size on disk as 3.35 gb.
anyone can share !?
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 22-12-2005, 10:02 AM   #2 (permalink)
All the files are stored not in terms of their actual size but in terms of their allocated size... Depending on the partition format (FAT16, FAT32, NTFS), the files are allocated a multiple of certain kb. Therefore, size of a file is different from the size allocated for it on the disk. For eg, NTFS uses multiples of 4kb (If I am not wrong). So, even if the actual file is only 100 bytes (many .ini files are very small), it will occuply 4 kb on the disk... If the file is 4.1kb actual size, it will occupy 8kb...
What is strange though is that the size on disk you have shown is less than actual size... Never seen that before...
Arun
sakumar79 is offline
Old 22-12-2005, 12:09 PM   #3 (permalink)
puja399's Avatar
Arun
I think its due to NTFS compression.
puja399 is offline
Old 22-12-2005, 01:50 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Yes its due to the NTFS file system's Compression.
In FAT if u see the size on disk will exceed the actual size. :roll:
Harsh J
www.harshj.com
QwertyManiac is offline
Old 22-12-2005, 01:58 PM   #5 (permalink)
alib_i's Avatar
yeah .. it must be NTFS file-system level compression ..
@anandk
do you have NTFS ?
does your system file show some files in blue colour ?
(those blue files are compressed files)
alibi
-Metallica
alib_i is offline
Old 22-12-2005, 06:32 PM   #6 (permalink)
anandk's Avatar
thnx 4 d info sakumar. btw, i have specefied the size/size on disks correctly.
thnx puja, quertymaniac.
yes alibi, i have ntfs. and some files do show in blue lettering.
Microsoft® MVP
anandk is offline
Old 22-12-2005, 06:59 PM   #7 (permalink)
alib_i,
i too hav some blue files, thou i dint intend to do anything to make it so! how do i revert it back? is it automatic? the process of compressing necessary files?
/legolas
legolas is offline
Old 22-12-2005, 07:01 PM   #8 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Some system files are automatically compressed via windows.
kalpik is online now
Old 22-12-2005, 07:03 PM   #9 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
Originally Posted by legolas
alib_i,
/legolas
it is a system default to show all NTFS compressed file in blue
u can change it in the folder options
vijay_7287 is offline
Old 22-12-2005, 07:08 PM   #10 (permalink)
puja399's Avatar
alib_i,
/legolas
U don't need to revert, NTFS compression is harmless (in fact, good), takes low CPU time, but u can't use NTFS encryption though if they r compressed (u can use 3rd party encryption). U can change option in 'Folder Option' to remove the blue colour, but I think its not necessary.
puja399 is offline
Old 23-12-2005, 03:57 PM   #11 (permalink)
alib_i's Avatar
legolas,
Leave it as it is ... there's no problem with it.
Windows usually compresses only files which are rarely used.
More reading:
Read Diesel's posts in :: http://forums.aliensoup.com/showthread.php?t=6985
alibi
-Metallica
alib_i is offline
Old 23-12-2005, 09:58 PM   #12 (permalink)
selva1966's Avatar
I was also worried about this difference in 'size' when I was choosing avatar. BTW which size is important to be below the 10KB limit.
selva1966 is offline
Old 27-12-2005, 01:52 AM   #13 (permalink)
alib_i's Avatar
I think it should be the actual size of the file.
Because mostly PHP users employ the filesize() function to calculate size of file and this function will always return the actual size in bytes.
Most people (and PHPbb too) dont take the pains to finding the 'size on disk' in these kind of cases.
But if you actually want to find the size of file on disk using PHP then you may take a look at shalless's post in THIS page
alibi
-Metallica
alib_i is offline
- by gohan89
