Old 22-12-2005, 07:58 AM   #1 (permalink)
Gracias Senor
dreams's Avatar
Default RAM Issue..
Hello all.. i hv a 256 MB RAM DDR.
I hv chkd in My Computer Properties it shows..
RAM Total Size 248 MB
In the BIOS it shows 256..
Wats wrong ?? RAM or My PC ??
I hv Intel 845 MOB with inbuilt Graphx n Sound.
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 22-12-2005, 08:15 AM   #2 (permalink)
8 Mb is used by ur onboard display card.... i think
Shwetanshu Srivastava
shwetanshu is offline
Old 22-12-2005, 08:36 AM   #3 (permalink)
::cyborg::'s Avatar
8 mb is used by video memory
::cyborg:: is offline
Old 22-12-2005, 09:04 AM   #4 (permalink)
MVP in VC++
You can see that missing memory allocated to video in the BIOS.
cvvikram is offline
Old 22-12-2005, 11:49 AM   #5 (permalink)
If u have seen carefully, the BIOS must be showing ur RAM as 24****KB + 8 MB shared.....This shared memory is for ur Video intensive applications
h_kunte is offline
Old 22-12-2005, 05:05 PM   #6 (permalink)
choudang's Avatar
don't worry, 8 MB is used by Video.
For every action, there is an equal and opposite criticism.
choudang is offline
Old 24-12-2005, 07:38 AM   #7 (permalink)
Gracias Senor
dreams's Avatar
Ya i hv seen it in BIOS.. like
AGP Aperture Size - 32MB
Frame Buffer - 8 MB
I think this is wat u r all talkin abt.. Wat is this AGP Aperture Size.. Can i change it to larger MB like 128MB.. Will it change my performance.. and also abt Frame Buffer..
dreams is offline
Old 24-12-2005, 07:58 PM   #8 (permalink)
choudang's Avatar
ok.... are you using intel board?
AGP Aperture Size: this is for setting up the AGP Card size.. if you installed AGP card.. put the card memorry size like 128/256...
Frame Buffer -- you can increase the size to maximum 16 MB.
choudang is offline
Old 25-12-2005, 07:46 AM   #9 (permalink)
Gracias Senor
dreams's Avatar
Ya of course i use Intel 845 MOB.. but i dont hv a AGP Slot in it and so No AGP Card.. All are integrated in MOB. So is it necessary to giv higher values for AGP Aperture Size.. and also Frame Buffer i hv max of 8MB only..
dreams is offline
Old 25-12-2005, 06:44 PM   #10 (permalink)
d
AGP Aperture size has nothing whatsoever to do with the memory of the AGP card. Increasing the AGP Aperture Size to huge values Will Not Increase the graphics perfomance of the computer. .AGP aperture size is simply the max system memory tht can be allocated for Graphics, if the video memory runs low....
The torquemaster rules.
d is offline
- by gohan89
