Old 21-12-2005, 10:28 PM   #1 (permalink)
Neil is Here...
coolendra's Avatar
Default How to change startup sound !!!!!!!!!
Mods may merge the thread coz coudnt locate 1
guys i am bored of the same old startup sound in Win XP
can any1 suggest any procedure to change the startup sound of win xp pro ............
i have many wav files whc i want to insert .............
plz hlp !!!!!!!!
If ELECTRICITY comes from ELECTRONS .. then i am sure MORALITY comes from MORONS
coolendra is offline
Old 21-12-2005, 11:14 PM   #2 (permalink)
open control panel
then open "Sound and audio devices"
in this select the sounds tab
here in program events select "Start windows"
and then browse the wave file u want to set as startup sound
solved
thadhanihemant is offline
Old 22-12-2005, 12:37 AM   #3 (permalink)
Yepp! That's it! There you find everything that makes win sound! So, not just the start, but the logon logoff and even refresh are changed there!!!
Ravi.
http://ravishchandra.blogspot.com/
Ravi+ish is offline
Old 22-12-2005, 09:51 PM   #4 (permalink)
Neil is Here...
coolendra's Avatar
Thanx guys
so simple !!!!!!!!!!
thanx ...
Old 23-12-2005, 03:12 PM   #5 (permalink)
If u hav a MP3 to WAV convertor....just convert any of ur fav songs toWAV & add it to the folder:
X:\WINDOWS\Media
And u can set ur favorite song to play on booting the PC!!!
Just keep in mind that the max size of the WAV file shud not be too large....around 100 to 150 MB only....
Enjoy!!
h_kunte is offline
Old 23-12-2005, 03:28 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
X:\WINDOWS\Media
Enjoy!!
Umm.. wont this slow down the startup ?
QwertyManiac is offline
Old 23-12-2005, 04:04 PM   #7 (permalink)
HEY QM....
Thats why I mentioned that the file size shud NOT be bigger than 100 to 150 KB.....thats the size the rest of the startup sound files are...
So no significant change is there in the startup time....
HK
h_kunte is offline
Old 23-12-2005, 04:07 PM   #8 (permalink)
Commander in Chief
Hehe.. see ur post.. u wrote MB, so I got confused
Harsh J
www.harshj.com
Old 23-12-2005, 05:37 PM   #9 (permalink)
Distinguished Member
anandk's Avatar
i prefer no sound 8) silence
nice question. nice answer.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 24-12-2005, 07:51 AM   #10 (permalink)
Awwww.... I did NOT realise that poop.....Well 100 MB for a startup sound file!!!...Hehehe...that will screw up the system......
Sorry mate...thanx for pointing out the blunder...
h_kunte is offline
Old 25-12-2005, 08:05 AM   #11 (permalink)
Gracias Senor
dreams's Avatar
I do these to make my PC Sound crazy.. I use Sony Sound Forge and cut particular verses frm any songs like "Come On..Come on.." some funky words and save it as wav file.. also u can talk in ur mike and record ur voice and can put it in ur startup sound.. like Welcome Boss or anythin u like..
..nJoy..
dreams is offline
- by gohan89
