Old 21-12-2005, 04:54 PM   #1 (permalink)
Default call of duty2
yesterday i have installed call of duty2 demo from 'digit DVD November'
after installation i click on desktop icon & also click on cod2sp_s.exe from installation folder,then it give message "cod2sp_s.exe has encountered a problem and needs to close.we are sorry for the inconvenience"
the error window having tabs "send error" & "don`t
send".
how can i solve this?
enderson is offline
Old 22-12-2005, 01:05 PM   #2 (permalink)
Reinstall...
And check error log...
Computer.
Whats that.
Is it some kind of frog.. turr turr turrr...
con_tester is offline
Old 22-12-2005, 01:36 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Whats ur sys config ? is it upto the minimum reqirements ? also before re-install please clear ur TEMP folder
Harsh J
www.harshj.com
QwertyManiac is offline
- by gohan89
