Old 21-12-2005, 04:14 PM   #1 (permalink)
LegendKiller's Avatar
Default Ram not working???
I have 256mb ram installed,but for few days i was experiencing slow downs and when checked my settings from my comp,it showed only 128mb ram on my pc!I opened my cabinet and re-installed both ram-chips(128*2),but still it shows only 128mb ram! what shld i do?
LegendKiller is offline
Old 21-12-2005, 04:20 PM   #2 (permalink)
MVP in VC++
Maybe u r memory slot is malfunctioning...try changing memory sticks to some other slot. test it
Also test the memory with
http://www.memtest86.com/
cvvikram is offline
Old 22-12-2005, 01:38 AM   #3 (permalink)
interestingly i re-installed ram and re-booted it showed 256mb ram,then now when i re-booted it again it showed 128mb ram? wats happening?
Old 22-12-2005, 08:37 AM   #4 (permalink)
::cyborg::'s Avatar
clean up the ram module
::cyborg:: is offline
Old 22-12-2005, 12:37 PM   #5 (permalink)
i did it ten times......but to no avail!
Old 22-12-2005, 12:44 PM   #6 (permalink)
The best thing u can do to check the problem is this.....
Insert ur RAM on some other PC (make sure that da speed matches) & see whether it is detected....If it gets detected then nothings wrong with the RAM module...
Alternatively, get some other RAM module from a friends PC & try it on ur mobo (again make sure that the speed matches)......If it gets detected, then u can rule out that ur memory slot is working perfectly....
And unfortunately, if both these things fail......time to take it to da doc....
I had done this thing a couple of years back & was successful in detecting a faulty memory slot...
h_kunte is offline
Old 22-12-2005, 03:42 PM   #7 (permalink)
i found it it was a faulty chip(128mb),the slots are fine!
- by gohan89
