Old 21-12-2005, 03:50 PM   #1 (permalink)
Default urgent help how to print .lwp file?
hi folks
i have a urgent document which is .lwp format . I want to know the application that can open this document and print it. word gives a scrambled view of this document.
this document is to be printed within 36 hours ,so please help.
shrohit is offline
Old 21-12-2005, 04:00 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
See this page for some details as to waht it is...
http://filext.com/detaillist.php?extdetail=LWP
Its pretty old.. so prolly less apps support it
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-12-2005, 06:49 PM   #3 (permalink)
LWP is Lotus Wordpro... Part of Lotus Smartsuite... It should be possible for you to download ftp://ftp.lotus.com/pub/lotusweb/pro...te/kvlot32.exe which is similar to Word Viewer... You can use it to read Wordpro document and then you can convert it to word... Formatting may be lost a bit but contents should be there....
Another alternative is that you can pm me and send me the doc by email... I have Lotus Smartsuite at my office... I can convert it to doc and send it back...
One more converter available is at http://www.download.com/3000-2279-68...ml?tag=lst-0-1 but it is shareware
Arun
sakumar79 is offline
- by gohan89
