Old 20-12-2005, 09:49 PM   #1 (permalink)
gdatuk's Avatar
Default Salvage the deleted file?
I recently deleted a 700mb large movie file out of my hard disk...without sending to recycle bin(shift del)..accidently..
Is there any way to retrieve the file....
i have win 2000 operating system....
any chance of getting the file back???
havent restarted or shutdown the system yet...waiting for ur replies....
Twitter @cgiridhar
Moto Milestone | Rooted | Froyo | CM 6.1.0
AMD Phenom2 720 x3 BE | Gigabyte MA78G | WD 500Gb+Seagate 1TB ext | PSU Corsair vx450 | Corsair 2x2gb RAM | Bose Companion 5
gdatuk is offline
Old 20-12-2005, 09:54 PM   #2 (permalink)
shariq_pj's Avatar
Use ant file recovery utility...
I don't remeber names of any now... Check it out in www.softpedia.com
There r loads of freewares and sharewares in that website...
Check out n Digit DVD's too...
Sh@riq
<size=24>P R ! V ! L E G E</size>
shariq_pj is offline
Old 20-12-2005, 10:15 PM   #3 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
u may also use tune up utilties.
and u may shutdown ur system in the meanwhile as restart should not cause any problems in recovering the deleted file , but further copying or moving file in that drive will do.
n00b forever...
~Phenom~ is offline
Old 21-12-2005, 08:52 AM   #4 (permalink)
ramprasad's Avatar
Try Easy Recovery or Get DataBack
ramprasad is offline
Old 21-12-2005, 08:53 AM   #5 (permalink)
use the best software ...
stellar phoenix .. provided u havent used the comp for more than a week or 2 u generally see the file
AMD Athlon 3500+ 939
Asus A8N-E
HDD: 860GB = 250 x2 + 160 x 2 + 40
Nvidia XFX 7600GT
2GB DDR RAM 400Mhz Transcend
17" LCD Viewsonic
ASUS Sata DVD writer
Logitech MX 518 + Steelpad Qck+
CyCo is offline
Old 21-12-2005, 12:23 PM   #6 (permalink)
Distinguished Member
anandk's Avatar
it will be posbl to retrive/undelete the file, if it is good condition or has notbeen written upon.use any good 'file undelete' software.
systemmechanic, ace utilities, tune-up utilities are some names which come to my mind.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 22-12-2005, 02:14 AM   #7 (permalink)
dIgItaL_BrAt's Avatar
Try PC Inspector file recovery.It has a high success rate of recovering data.
dIgItaL_BrAt is offline
- by gohan89
