Old 17-10-2004, 09:00 PM   #1 (permalink)
Default HELP HELP HELP.....RAID HELP
I hav two samsung 40gb harddisks in raid array-stripping on asus intel 865 motherboard. I/windows think my HDD has developed bad sectors
i just downloaded spinrite5 and ran it with a bootable disk but it cannot see my hard disk .
1)I want to know that is there any way to make spinrite see my harddisk
2) or is it possible to disable raid in BIOS and set it to IDE in BIOS and then run spinrite. After running spinrite then can i reenable the raid array without loosing any data
HELP HELP HELP urgent plz plz
ramu is offline
Old 17-10-2004, 10:15 PM   #2 (permalink)
JAK
What the Heck !
JAK's Avatar
Default Re: HELP HELP HELP.....RAID HELP
Hmm....
Well..........
Ans 1. : well i dont think u can make spinrite see a HDD in a raid volume...well an easy way out wud be to remove the hDD's and connect them to a different machine and then run Spinrite on them....
Ans 2: Well i too hav raid0 but hav never personally tried the thing u hav in mind ...... But if i aint wrong in the Raid BIOS there is a "Rebuild Raid Array" option...(atleast its there in mine) so i think what u hav in mind is quite possible. I wud hav tried it myself but but i cannot afford a data loss of abt 160GB...
Maybe somebody else has done it...
wait till others reply...
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
JAK is offline
Old 18-10-2004, 07:48 AM   #3 (permalink)
You are using an old version of spinrite. The latest spinrite, spinrite 6 is filesystem independent- it even works with Raid.
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
[deXter] is offline
Old 19-10-2004, 12:13 AM   #4 (permalink)
Dexter's right download latest Spinrite and then try.
Q : What\'s Flash ?
A : The fastest thing in the world.
Q : Who am I ?
A : The Quickest [flAsh]
[flAsh] is offline
Old 19-10-2004, 04:22 PM   #5 (permalink)
JAK
What the Heck !
JAK's Avatar
Woah.. ur right Dexy....i just checked it with Spinrite6...
JAK is offline
Old 19-10-2004, 11:47 PM   #6 (permalink)
which raid controller do you use i too am interested in setting u[ a sata rain on my asus 865 mobo
**** happens
pradeep_chauhan is offline
- by gohan89
