Old 19-12-2005, 01:54 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Installing DOS ! ! !
how 2 install dos & will it work with Xp ??? not dos of xp ...
whots the latest version ??? frm where can i download it ???
as i wanna run my norton full system scan through dos ... will work faster than running through Xp ...
ax3 is offline
Old 19-12-2005, 03:46 PM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
goto www.bootdisk.com and download any of the win98se or winme boot image. burn a cd will all the stuff and boot. or if you can get a win98/me boot floppy (if u still use floppy drive!)
you can't install dos wid windowsxp coz winxp will simply replace it!
infra_red_dude is offline
Old 19-12-2005, 04:38 PM   #3 (permalink)
d
yea maybe tht might work....but i ain't really sure if the win98 version of DOS will be able to read into NTFS partitions? u'd better check...
The torquemaster rules.
d is offline
Old 19-12-2005, 04:56 PM   #4 (permalink)
To read NTFS partitions from dos, you need a NTFS Reader for DOS software (free)... But, to delete/modify stuff in NTFS partition from dos, you need to get paid software...
Get FreeDOS available at www.freedos.org and you can make a boot cd using freeware such as Bart's tools at http://www.nu2.nu/bootcd/
Arun
sakumar79 is offline
Old 20-12-2005, 01:54 PM   #5 (permalink)
Wire muncher!
well since he mentioned that he wants to run that software thru dos, i suppose he has fat32 partitions.
anyways, if you can't do that then just download Bart PE creator from:
http://www.nu2.nu/pebuilder/
create ur own rescue disk will all the utilties and run that softie thru a windows environment wid almost everything stripped. hmmm...its somthing like a gui for dos wid 32bit drivers loaded
Old 21-11-2008, 04:20 PM   #6 (permalink)
Default Re: Installing DOS ! ! !
hi sir, I am Luckybadal. my system is amd 4600+ ram 1gb 800FSB Transand hard disk 250gb. I have a problem . my system is not working well when ever i use it he give the problem of virus dubble click.when we select any folder or application it itself execute withought any command given by us.i have installed windows xp SP2 many time. i also have used kaspersky 2009, avast, AVG9 and updated them regurally but the problem is still remain.please help us.
regards:
Luckybadal
Patiala
Cell: 9914210041
heritage_2141 is offline
Old 21-11-2008, 05:40 PM   #7 (permalink)
AFK
thewisecrab's Avatar
You bumped a DOS installation 3-yr-old thread for a Virus problem?
Thats
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 21-11-2008, 06:24 PM   #8 (permalink)
hansraj's Avatar
Hey heritage_2141 welcome to forum... but it looks like you have posted a querry anywhere you felt like. U can create a new thread for all your querries (rather than creating record of bumpin an old thread)which is what this forum is meant for and tell your problem in a bit detail ... like how it started, symptoms, actions taken by you and the results thereafter. We all here might be able to help you(few here are really genius)
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
- by gohan89
