1. Well, if there are mpg or other video files that you're looking to record, then you can easily merge them into a simgle file using softwares. If they are picture files, you can create a panaroma image to merge all of them into a single image using Irfanview
Or else, you can create an archive using Winrar or Winzip to keep all those files in one rar or zip file which you can burn & view later on.
2. Regarding centering the text, have you tried the toolbars for Formatting? Select the text and click on Centre in the toolbar.
3. Select the paragraph, and choose
"Justify" from the Formatting toolbar. This will make the letters in the para come in a straight left & right margin.
4. Open the file that you want to print, go to
File menu->Page Setup...
This opens a dialog box. Decrease the margins of top & bottom to about 0.4 or anything of your choice.
5. Just like the above, Open the webpage in IE, go to File Menu->Page Setup..
Enter the margins or according to your problem, decrease the margin on the right side of the page.
Hope you were looking for such answers
Regarding the multiple posts, have patience, there are thousands of users on this forum, some may be away for some time, but there are a great chance that atleast one of them will reply.!!
Savvy!!
