Old 18-12-2005, 06:16 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default Which Spyware program should I use???
Hello Friends!
I am presently using Webroot Spy Sweeper 4.5 which I got from the net along with the key. The problem is that it doesn't update it's defination and so I am open to all new spying stuffs.
See, I have no intentions of discussing about pirated softwares, but just the problem I am facing. Is there a way to update it's defination apart from the update link in the software itself which I have already tried and failed. Incase not, please recommend me some other good spyware software that has a real time protection feature.
Thank you.
go4saket is offline
Old 18-12-2005, 06:20 PM   #2 (permalink)
i use microsoft antispyware and spybot s&d
n im really satisfied wid dere results
ishaan is offline
Old 18-12-2005, 06:21 PM   #3 (permalink)
dIgItaL_BrAt's Avatar
Spybot S&D is the best,it really does a through job.
dIgItaL_BrAt is offline
Old 18-12-2005, 06:33 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
i suggest u use 2 atleast.
microsoft anti-spyware AND
adware OR spywaredoctor v 3.1 (freeware) OR spybot.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 18-12-2005, 06:53 PM   #5 (permalink)
I think the one by MS... is the best,,... it works REALLY well and updates itself too.. the intrface as slick as u expect from MS!!!
Ravi.
http://ravishchandra.blogspot.com/
Ravi+ish is offline
Old 18-12-2005, 07:00 PM   #6 (permalink)
Spybot S & D with all the updates is the best spyware deticting s/w around.....Its scanning rate is fast & is really efficient...
Else use a firewall, to know beforehand about any access attempt which might be made to your PC......An access attempt might however not be a spyware at work at all times....
h_kunte is offline
Old 18-12-2005, 07:49 PM   #7 (permalink)
Rebooting
Choto Cheeta's Avatar
None
man.... u r suppose to use Anti Spyware program to get rid of the spyware program infecting ur PC... why would one want spyware in his PC??
lol....
anyway... i support ishaan,
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 18-12-2005, 11:17 PM   #8 (permalink)
9437077259
go4saket's Avatar
Thanks a lot for all your recommendations but as you guys suggested, Spybot and MS Anti Spyware, I found problems with both of them.
Spybots doesn't provide a real time protection. Thus it allows the spy softwares to enter your system and you can only get rid of them when you go for a system scanning. What I wanted was some software which wouldn't allow the spywares to enter my system atall.
As for MS Anti-Spyware, I used it for some time but never did I find it detecting any spy's which other softwares like Spy Sweeper & Spy Bots found many that were present in my system. Forget about that, I purpously installed a spying software called Starr with MS Anti-Spyware installed but it never detected it. So I find this software to be absolutely useless.
Talking about a firewall, it's work is to inform you which softwares are using your network. Now if I am using Yahoo Messenger for example which has a built in spying software, all the firewall is going to tell you is that Yahoo is using your network connection. Once you allow Yahoo, the path for the spying softwares are wide open. In the same way there are so many syping software that send mails through your system which cannot be blocked with a firewall.
So let find some thing that can actually stop spying softwares to actually enter your system.
go4saket is offline
Old 19-12-2005, 06:11 PM   #9 (permalink)
anandk's Avatar
None
[b]
ur answer rocks ! all the rest of us gave dud answers !!!!
anandk is offline
Old 20-12-2005, 07:22 PM   #10 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
i use spycleanergold
vijay_7287 is offline
Old 20-12-2005, 11:52 PM   #11 (permalink)
swatkat's Avatar
SpycleanerGold is a rogue software. Using it is not encouraged. Read more here.
http://swatrant.blogspot.com/
swatkat is offline
Old 21-12-2005, 06:59 PM   #12 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
no it is'nt
the same site u gave clarifies it, c this
http://www.spywarewarrior.com/rogue_...tm#scgold_note
Old 21-12-2005, 09:54 PM   #13 (permalink)
I use MS Antispyware and Spybot S&D
Shwetanshu Srivastava
shwetanshu is offline
Old 21-12-2005, 10:45 PM   #14 (permalink)
Neil is Here...
coolendra's Avatar
spybod S&D is good
u can also try Microsoft AntiSpyware .........
nice interface
If ELECTRICITY comes from ELECTRONS .. then i am sure MORALITY comes from MORONS
coolendra is offline
Old 21-12-2005, 10:48 PM   #15 (permalink)
royal's Avatar
Ad Aware Pro and XoftSpy... A lethal combination 8)
royal is offline
Old 22-12-2005, 02:06 AM   #16 (permalink)
AdAware+Spybot is an effective combo
Old 26-12-2005, 12:45 AM   #17 (permalink)
Use spyware blaster too.It mainly blocks the bad downloads of files.And it doesnt need to be running.Just immunise and exit.
hsksattish is offline
Old 26-12-2005, 01:23 AM   #18 (permalink)
i think ewido provides realtime protection.
http://www.ewido.net/en/
ashnik is offline
- by gohan89
