LinkBack (1) Thread Tools Search this Thread Display Modes
Old 18-12-2005, 06:14 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default http://registration.sancharnet.in:8080/ not working.
http://registration.sancharnet.in:8080/ not working.when i tried to click it simply show's a blank screen.I have tried in all browser's and even by reformating.But it works fine in win98.what could be the problem????help me...........
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 18-12-2005, 06:18 PM   #2 (permalink)
it worked in mine,,,it said this on the homepage:
Internet Explorer Users : (IE 5 or Later)
Check the Browser Version by clicking "Help" on your Browser tool bar and then clicking "About Internet Explorer".
Step 1: On your browser tool bar go to Tools --> Internet Options --> Advanced --> Security
Step 2: Choose "Use SSL 2.0", "Use SSL 3.0" and "Use TLS 1.0"
Step 3: Click on Ok
and evn for netscape browsers
mebe ur security settings r not fine try that
ishaan is offline
Old 18-12-2005, 07:04 PM   #3 (permalink)
But this tip also dosen't work.Any more????help me plz.........
rajas700 is offline
Old 18-12-2005, 09:16 PM   #4 (permalink)
desertwind's Avatar
Works in mine too. Me uses Fx on FC4
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 18-12-2005, 09:35 PM   #5 (permalink)
Then what could be the problem??I have reinstalled the os itself.But no use.......
rajas700 is offline
Old 18-12-2005, 09:42 PM   #6 (permalink)
Are u using a pirated OS.
Some Pirated contains viruses and trozens.
I experianced it....
Computer.
Whats that.
Is it some kind of frog.. turr turr turrr...
con_tester is offline
Old 18-12-2005, 09:54 PM   #7 (permalink)
I have OEM PROFESSIONAL CD......
rajas700 is offline
Old 18-12-2005, 10:19 PM   #8 (permalink)
Rebooting
Choto Cheeta's Avatar
dont know much about the service... but hope u did all this,
Originally Posted by Sanchernet
Dear Customer,
Online Registration System ensures secured service. Please enable browser security settings using the following procedure.
Step 3: Click on Ok
Netscape 4.7 Users:
Check the Browser Version by clicking "Help" on your Browser tool bar and then clicking "About Communicator".
Step 1: On your browser Navigation toolbar, Click on "Security"--> Navigator --> Advanced Security SSL Configuration
Step 2: Choose "Enable SSL v2" and "Enable SSL v3".
Step 3: Click on Ok.
Netscape 6.0/7.0 Users:
Check the Browser Version by clicking "Help" on your Browser tool bar and then clicking "About Netscape".
Step 1: On your browser tool bar go to Edit --> Preferences --> Privacy & Security --> SSL
Step 3: Click on Ok
Please remember to proceed further the browser security settings has to be enabled.
Choto Cheeta is offline
Old 18-12-2005, 11:58 PM   #9 (permalink)
swatkat's Avatar
Hmmm...Do you have Java Runtime Environment installed? If not, get it from this month's Digit CD/DVD or from here.
http://swatrant.blogspot.com/
swatkat is offline
Old 19-12-2005, 06:10 AM   #10 (permalink)
I have got this before 2 years back.....................
rajas700 is offline
Old 19-12-2005, 01:09 PM   #11 (permalink)
Problem Resolved By uninstalling Norton Internet Security 2006.when in uninstall Norton Internet Security 2006 it works fine.when i reinstall Norton Internet Security 2006 it again show's the old problem.So what could be wrong with Norton Internet Security 2006????Any one help me.............
rajas700 is offline
Old 19-12-2005, 01:12 PM   #12 (permalink)
Commander in Chief
QwertyManiac's Avatar
^^ It might be blocking scripts for security... see in the options...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 19-12-2005, 01:24 PM   #13 (permalink)
No such a script blocking option found in Norton Internet Security 2006.In Norton Internet Security 2005 it work's fine.So i think there must be a bug in the Norton Internet Security 2006????QwertyManiac can u help me to solve this problem??????
rajas700 is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/qna-read-only/20612-http-registration-sancharnet-8080-not-working.html
Registration Sancharnet 8080 - 3D Search This thread Refback 01-07-2010 02:06 PM
- by gohan89
