Old 18-12-2005, 03:29 AM   #1 (permalink)
Default unable the write cds at 48x
hi all
i jus got a new sony dru 810a dvd writer,...
i'm unable to write cds at speeds greater than 40x...
although i think that this writer is capable of writing at 48x
pl correct me anyone if i'm wrong...
and please help.
tia
manmay
manmay is offline
Old 18-12-2005, 03:31 AM   #2 (permalink)
also i must mention...
my rig is
amd 64 3000+ msi rs480m2 512 mb 80gb sata hitachi+80gb pata seagate.
manmay is offline
Old 18-12-2005, 03:36 AM   #3 (permalink)
dIgItaL_BrAt's Avatar
The DRU 810A does write at 48x but Sony set the default read/write speed to 40x to minimize the drive noise.To read and write discs at 48x,u have to activate the Turbo Boost mode.
1) Insert a CD-R/CD-ROM disc into the drive
2) Press and hold the Eject button for five seconds.
The busy indicator blinks twice and the read/write speed switches to 48x. (The Turbo Boost function is active.)
When you open the disc tray, the Turbo Boost function will be deactivated.
dIgItaL_BrAt is offline
Old 18-12-2005, 03:45 AM   #4 (permalink)
alright man...
that's a cool feature...
achha does it also work for dvds
thanks for the info
manmay is offline
Old 18-12-2005, 03:52 AM   #5 (permalink)
That feature only works for CD's.
Old 19-12-2005, 09:43 AM   #6 (permalink)
q3_abhi's Avatar
Sometimes it does depends on the type of media used for writing .
Try using gud quality media for writing.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 19-12-2005, 10:22 AM   #7 (permalink)
Commander in Chief
QwertyManiac's Avatar
hey will that turbo function occur for other drives too ? I have a samsung one
Harsh J
www.harshj.com
QwertyManiac is offline
Old 20-12-2005, 11:07 PM   #8 (permalink)
why dont u just try this method out....
manmay is offline
Old 20-12-2005, 11:10 PM   #9 (permalink)
Wire muncher!
infra_red_dude's Avatar
no the turbo mode is exclusive for sony cdroms/cdrws (and probably for liteons as they are the oem suppliers)
also, while copying from a cdrom/rw drive activate turbo mode by pressing the eject button for 5secs to fasten the copying operation! works very well!
infra_red_dude is offline
- by gohan89
