Old 18-12-2005, 03:08 AM   #1 (permalink)
Default i find rmvb much better...
with due regards to the thread run by maverickrohan some time back abt the video codecs...(but i think he didnt consider the real media.....anyway..), i find the real media variable bitrate better than all those others divx xvids and vp62 ...
i am using a freeware tool easy real media tools for converting purpose...
and the settings are...
70% quality avg 450kb bitrate with peak of 900kb variable.
video noise reduction low.
audio gain 4-6...as needed.
real codec 10.
and yes i would like to mention that the output in real media using softwares like winavi was not up to the mark...so had to switch over to easy rael media tools...moreover this one provides some nice and useful advanced settings
yest i converted the DCH movie original vcd to *.rmvb
using the settings mentions ed above.
originally the movie is of 3 cd totalling to abt 1.9 gigs.
after conversion the output was totalling 688 mb almost 1/3 and the video quality was really commendable...seriously try out for yourself.
for storing the movies on dvds it really good yaar...
i dont know whether its becoz of this tool or smething else but just try it out urself...
the conversion speed was less than divx or vp62.
on my rig...
amd 64 3000+ 939 pin msi rs480m2 512 mb running at 1.9 ghz...
the frame rate achieved was 25 fps +- 5
some more information is invited and so r your comments...
manmay
dawn is a natural indication by nature to you to go to sleep
manmay is offline
Old 18-12-2005, 12:06 PM   #2 (permalink)
gxsaurav
Posts: n/a
rmvb is good but just like vp7 & there own player, it need Real player to play properly, unlike DivX which can be played on any Directshow compatible video player.
the popularity of real player isn't that much either, if u can manageto like it, it's one of the most compleate players out there, it's just it bugs a lot to upgrade, u have to apply a crack for this naging to go even if u r using the free version, as it still says, "upgrade to pro",
DivX 6.1 do try it, u got an athlon64 it will really help in encoding times, also u need to configure a video codec properly before using it, one size & bitrate doesn't fit all
Old 18-12-2005, 07:20 PM   #3 (permalink)
kindly elaborate
"...also u need to configure a video codec properly before using it, one size & bitrate doesn't fit all"
please...
manmay is offline
Old 24-12-2005, 09:14 PM   #4 (permalink)
Maverick340's Avatar
CAn you use Virtual Dub TO encode it into RMVB??
IF so please give the link to the codec(if its free)
You and Me forever be ...
PSpwned
Maverick340 is offline
Old 28-12-2005, 11:25 PM   #5 (permalink)
No, you need Real's Helix Producer a.k.a. Real Producer.
-Keith
Keith Sebastian is offline
Old 28-12-2005, 11:51 PM   #6 (permalink)
ya thats right do try that....its quite good and a freeware....
manmay is offline
Old 26-02-2006, 05:26 PM   #7 (permalink)
slugger's Avatar
well i played an rmvb file in winamp.
just rename d extension from *.rmvb 2 *.mpg and it played without a hitch
slugger is offline
Old 26-02-2006, 05:40 PM   #8 (permalink)
your renaming didnt do this magic slugger.
its becoz the codecs for rmvb hav already been incorporated in your system so now u can play the file any played.
u can even play the rmvb file in windows media player.
do u think WMP supports the real format traditionally.?
manmay is offline
Old 26-02-2006, 05:45 PM   #9 (permalink)
slugger's Avatar
i got real alt installed.
but i tried 2 plat the file wit ext *.rmvb in winamp but it did not play. it was only after i renamed d ext 2 *.mpg did it start playing [actually d first time i tried playing it after renaming, my sys just hung, but since den i faced no problem]
slugger is offline
Old 27-02-2006, 05:11 PM   #10 (permalink)
You can use Codec Packs to play the rmvb movie in the Windows media player itself....It si not necessary to play in real player only
dabster is offline
Old 27-02-2006, 08:25 PM   #11 (permalink)
slugger's Avatar
yup u r right. the file stopped playing once i uninstalled real alt.
btw downloaded d sw, THNX A TON MAN. will try it out
but d Qs still remains. Y did d file play in Winamp only after I renamed d ext and not before
slugger is offline
Old 28-02-2006, 04:10 AM   #12 (permalink)
winamp does not recognize this format.
generally softwares just check the extension of the file to check its compatibility.
by changing the ext u made a fool out of winamp by making it think that this is a playable foramt. and becoz the codec were already installed so it was able to play the file.
try this.
make a .rar archive using winrar.
suppose name it try.rar
the icon for the rar file will change to the application that handles the jpgs
now u double click the file . u will c nothing.
now right click the file and select open with and choose winrar.
winrar will obviously open it coz its actually a rar file.
manmay is offline
Old 28-02-2006, 11:43 PM   #13 (permalink)
Opensource rules. Go XviD.
If you can't get better quality using Xvid as compared to RMVB (for the bitrates you've mentioned), you're doing something wrong. Check out the doom9 yearly codec shootouts. Also get Gordian Knot and a good guide on encoding using Xvid in GK.
Cheers,
Keith
Old 01-03-2006, 08:20 PM   #14 (permalink)
bizzare_blue's Avatar
Is it possible to convert original DVD's to rmvb using this tool? n for that matter legal too?
Bitten by the open-source bug...
bizzare_blue is offline
Old 02-03-2006, 04:43 PM   #15 (permalink)
yes u can and it is.
manmay is offline
Old 02-03-2006, 04:47 PM   #16 (permalink)
manmay is offline
Old 03-03-2006, 12:35 PM   #17 (permalink)
Thnx manmay....It was really gr8 tool...nice output...
Old 03-03-2006, 10:28 PM   #18 (permalink)
Neil is Here...
coolendra's Avatar
it seems that rmvb is gettin more popular here.
good
me usin it for a long time !!!!
If ELECTRICITY comes from ELECTRONS .. then i am sure MORALITY comes from MORONS
coolendra is offline
Old 04-03-2006, 03:43 AM   #19 (permalink)
hey bizzare blue pl tell us what was the size of input file and out file. and the settings that u had kept.
manmay is offline
Old 04-03-2006, 01:29 PM   #20 (permalink)
The input file size was 1.31 GB and the output file size 385 MB...I kept the as u had mentioned in this thread i.e. 70% quality, audio gain 6 and Real codec 10....
The input file was a VCD....the input n output files had no visible difference but vol was increased so overall a gud exp with rmvb
Old 04-03-2006, 08:59 PM   #21 (permalink)
that's gr8.
try converting a .vob file using this.
well i prefer auto gordian knot for converting vobs to xvids. (dont know y.)
c the results.
happy converting....lol
manmay is offline
Old 05-03-2006, 04:15 PM   #22 (permalink)
slugger's Avatar
r there any freewares available dat allow u 2 check out @ wat seetings a particular *.rmvb file has been encoded.
slugger is offline
Old 06-03-2006, 12:52 AM   #23 (permalink)
ya man this probs buggin me for some time.
nebody know the solution to this.
manmay is offline
Old 03-04-2006, 11:59 PM   #24 (permalink)
too good manmay. Keep it up! I didnt use RMVB before, but reading this, changed my mind. Its goooooooood.
Aakash Shah
aakash is offline
Old 07-04-2006, 04:15 AM   #25 (permalink)
Learner
Kniwor's Avatar
well i know it's legal if u own it... duno about if u can
well i asked people about rmvb sometime back because i came across some good files, but nobody responded...... infact i asked 2-3 times.....
good, and thanks...
Kniwor is offline
Old 07-04-2006, 10:46 AM   #26 (permalink)
yes surely u can easy real media tools has the capability to convert dvds to rmvb ....
but as i mentioned before....for dvds AGK is the best.converting tool...
manmay is offline
Old 16-04-2006, 11:28 PM   #27 (permalink)
jay4u's Avatar
-Keith
google and you will find a free mpg/avi to rmvb converter called easy real producer or something..... which according to me is better than real producer....
Passwords are like underwear... Change them often...
jay4u is offline
Old 17-04-2006, 12:41 AM   #28 (permalink)
i think both of em r same...
manmay is offline
Old 17-04-2006, 01:50 PM   #29 (permalink)
Ethan_Hunt's Avatar
I have seen just a single movie which was or .rmvb compression and Man I am definetly amazed with the Quality reproduced.The size was a mere 352MB which was quite good compared to the Quality loss.Is this codec available for free and can movies be converted using this codec via Virtual Dub?
V for Vendetta
Ethan_Hunt is offline
Old 17-04-2006, 08:50 PM   #30 (permalink)
no virtual dub or the mod version will not recognise rmvb.....pl jus go thru this thread in its entirety....that will solve your doubt.
manmay is offline
- by gohan89
