Old 17-10-2004, 12:58 PM   #1 (permalink)
Default COMPUTER RESTARTS
I am having RH 9 & windows XP with SP2. On booting the computer(GRUB boot loader),when the desktop is being loaded ,the computer restarts and when it again restarts first scandisk operation is performed and then when the desktop loads a message appears
The system has recovered from a serious error.
When I see the technical information it states:
The following files will be included in the error report:
C:\Documents\Locals~1\Temp\WER3bf8.dir00\Mini10170 4-01.dmp
C:\Documents\Locals~1\Temp\WER3bf8.dir00\sysdata.x ml
What seems to be the problem?????????
It\'s a truism that our worst affected wounds are self inflicted
Just Another F*$%/ed up day in Paradise
SHell is offline
Old 17-10-2004, 03:42 PM   #2 (permalink)
- check ram , switch ram modules , chkdsk /r , defrag
- did u get any error msgs in event viewer
klinux is offline
Old 17-10-2004, 05:13 PM   #3 (permalink)
Is redhat booting properly ??
If not then som thing is wrong with your RAM else if the problem continues
try to boot in safe mode by pressing f8 during booting.
Insafe mode Scan for any virus and preform a scandisk.
To run scandisk in run write chkdsk /F X:
Replace X: with your system disk
Generally it is C:
This could slove your problem.
BlAsTeR is offline
Old 18-10-2004, 06:06 PM   #4 (permalink)
Red hat Linux is working properly
no problems with that.
chkdsk also did not gave any errors...
What can be the problem
SHell is offline
Old 19-10-2004, 01:41 AM   #5 (permalink)
hi i thnk u r using fat32 as a partition for win xp
sometimes even if a small problem occurs.. the chkdsk facility runs
now boot in safe mode
go in my computer > properties > advanced
click on error reporting and disable error reporting
futher in the advanced properties ckick o setting options and uncheck the option of restart on sys error
hope ur problem is solved
Attack life, it\'s going to kill you anyway.
walking-techie is offline
- by gohan89
