Old 17-12-2005, 04:19 PM   #1 (permalink)
Default flash websites cannot be opened!!
see,
i cannot view certain websites.when the window is open,an outline comes and then it stops there.
no blocks are done by any antivirus.
hw can I solve it?????
i think the flash websites are the problems.
plzzzz help meee
dittualex is offline
Old 17-12-2005, 04:50 PM   #2 (permalink)
download the latest version of flash
or u can just insert the digit cd or dvd and in the screen ware u gotta clik i agree/disagree, dere is a link wich will install flash player 8 for u
dat shud load em fine
btw, in mozilla and IE, flash has 2 installed seperately
ishaan is offline
Old 17-12-2005, 05:22 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
also check (if u use Fx that is) whether No Script is blocking the SWF from loading
Harsh J
www.harshj.com
QwertyManiac is offline
Old 17-12-2005, 05:51 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
also check if ur browser is 'set' to block flash content. or in u r using spywareblaster check that too.
best if u download the latest (i think 8) version of it.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 17-12-2005, 11:45 PM   #5 (permalink)
well.. i hav seen ppl have this problem even if... they had alll of the above advises taken... honestly speaking i don't know what else to do... MAAAAYYYYYYBBBBEEEEE the installation of the Flash ... i mean the creation software by macromedia helps... but there's a big mayb.
So, i when i have no soln. i wud suggest.... format and reinstall.... which is always hard to do.... but CAn be good if you have not dun that for a LLLOOOOONNNGGG time!!
Ravi.
http://ravishchandra.blogspot.com/
Ravi+ish is offline
Old 17-12-2005, 11:52 PM   #6 (permalink)
dude dont reformat for lousy prob like dis...if u reinstall flash n it still dont work, or those browser settings, then just reinstall ur browsers
update ur windows also, update display drivers...
or get a copy of flash mx or something...not the player i mean the whole software wich is used 2 create flash files n install that...then u can uninstall it also but all the important browser components will remain
most prob u wont hafta do dese frantic measures but seriously dis prob aint worth a reformat
unless u got loadsa other probs n u dont mind backin up ur data n reinstalling evrything, dont reformat
ishaan is offline
Old 18-12-2005, 05:54 PM   #7 (permalink)
Formerly Spashy
Sparsh007's Avatar
download the latest version from the net 8)
Sparsh007 is offline
Old 18-12-2005, 06:15 PM   #8 (permalink)
i said the same thing... to try to reinstall the whole software by macromedia.... And after that... when u don't know anythign else,,, and,,,are desperate to get it fixed,,, there is the ramban!!!
Ravi.
Ravi+ish is offline
- by gohan89
