Old 16-12-2005, 11:13 PM   #1 (permalink)
Default Unable to remove PPPoE miniport -> dev. mngr
I couldnt uninstall this device marked with an exclamation mark... How do i uninstall it otherwise? its connected with the PPPoE installer that comes with Airtel Broadband... my computer hanged when uninstalling and since then i am not able to uninstall.. if i use the installer again to get PPPoE, another PPPoE controller comes in an this one stil retains there. however, i am connecting to internet by using windows XP dialer now with PPPoE interface. but i need to uninstall this one and install fresh the driver. pls suggest ur options. thk u.
/legolas
legolas is offline
Old 17-12-2005, 09:13 AM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Try removing it in safe mode.
kalpik is online now
Old 17-12-2005, 03:07 PM   #3 (permalink)
cudnt remove in safe mode either
/legolas
legolas is offline
- by gohan89
