Old 17-10-2004, 08:57 AM   #1 (permalink)
Default help reqd
hi ppl,
i was told that when u r using cable internet & use the ping command specifically "ping (server address) -t -l (no. of bytes)" then the ping command should yeild a reply for all the values for no. of bytes b/w 32 to 65527 & if it is not yeilding a reply for the highest value i.e. 65527 bytes THEN YOU HAVE A PROBLEM WITH THE CONNECTION/ WIRE ETC. & YOUR INTERNET/ DOWNLOAD/ UPLOAD SPEED will also get affected.
my question is that whether it is true that ping command should yield a reply for all values & secondly in case it is not yeilding a reply for higher values then is there any problem with the wires or connectors etc ?
vijay
connecttovijay is offline
Old 17-10-2004, 09:53 AM   #2 (permalink)
You see ... the ping would show the time taken for a fixed amount of data to travel between you and the selected destination. For large values the time would be much larger. Therefore it would show request timed out probably. Secondly, i checked and the max value seems to be 65500
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 17-10-2004, 10:45 PM   #3 (permalink)
thnx 4 the reply ujjwal. normally the ping command replies @ around 1400 bytes. so can it be assumed that if the ping command replies @ this value then there is no problem with n/w speed, wires & connectors ?
Old 18-10-2004, 01:25 AM   #4 (permalink)
connecttovijay
SO first welcome here dude
any way u have finded ur answer by ujjwal.
Music is like Sex, The more you get, the more you want.
demoninside is offline
- by gohan89
