Old 16-12-2005, 06:23 PM   #1 (permalink)
Neil is Here...
coolendra's Avatar
Default What is Slipstream ?????
Recently i overheared some ppl talking bout slipstream and was curious to know what it acually was.......
does any1 has a complete idea bout what it actually is ????
If ELECTRICITY comes from ELECTRONS .. then i am sure MORALITY comes from MORONS
coolendra is offline
Old 16-12-2005, 06:38 PM   #2 (permalink)
Slipstream is the concept of inserting the various patches to a software (usually, OS) so that it is installed with the latest patches directly. For instance, from the Windows XP installer CD, you can append the Service Pack 2 and later patches and create a new installer CD that will automatically install SP2 and the patches immediately after installing XP...
Arun
sakumar79 is offline
Old 16-12-2005, 07:21 PM   #3 (permalink)
kumarmohit's Avatar
Not immediately after dear but right within the actual installation of software
kumarmohit is offline
Old 16-12-2005, 09:32 PM   #4 (permalink)
Neil is Here...
coolendra's Avatar
is it legal .......????
Old 16-12-2005, 10:01 PM   #5 (permalink)
It is legal as long as you own the installer cd which you are slipstreaming...
Arun
Old 16-12-2005, 11:02 PM   #6 (permalink)
The Hardware Labs
mohit's Avatar
Slipstreaming is the process of integrating the numerous patches / service packs released for a particular software directly into the old installation cd to save u from the hassle of installing the patches later or everytime u reinstall the os/software. there are many software available for slipstreaming different software with their patches.
for windows xp u can try this tut if u want to make a new installation cd complete with the latest patches and sp2,
http://www.thinkdigit.com/forum/viewtopic.php?t=18785
mohit is offline
Old 18-12-2005, 12:11 AM   #7 (permalink)
well. are you SURE you're not talkin' abt clip stream??? YOu may be actually talkin abt slipstream.. but if it' not ut.. and u wre looking for that audio and video streaming software to use for ur site... then it's clipstream..
Anyways, i just thought!!
Ravi.
http://ravishchandra.blogspot.com/
Ravi+ish is offline
Old 18-12-2005, 12:43 AM   #8 (permalink)
Learner
Kniwor's Avatar
u can also include some programs into installation..
like u can get the adobe acrobat reader, everest, ur free antivirus etc.. into it so that when i install with the slipstramed CD u get all this installed automatically
Kniwor is offline
Old 18-12-2005, 10:01 AM   #9 (permalink)
Commander in Chief
QwertyManiac's Avatar
http://en.wikipedia.org/wiki/Slipstream_%28computing%29
Harsh J
www.harshj.com
QwertyManiac is offline
- by gohan89
