Old 16-12-2005, 09:31 AM   #1 (permalink)
Default TV tuner HELP
Which TV tuner should i go for ? PLZ tell me all its prices ?
What are their capabilities ? What exeactly will it do ??
sagargv is offline
Old 16-12-2005, 01:18 PM   #2 (permalink)
Well. First tell Do u need a external; or a internal.
External can reduce ur electricity bills but cant captue shows but internal will capture but cant reduce electric bills.
Which one u want....
Computer.
Whats that.
Is it some kind of frog.. turr turr turrr...
con_tester is offline
Old 16-12-2005, 08:36 PM   #3 (permalink)
i think internal . Price ?? what all can it do ?
sagargv is offline
Old 17-12-2005, 05:06 PM   #4 (permalink)
ofcourse u can spture wid external
i got a pinnacle pctv usb2 100e and u can capture perfectly with it
u can do everything wich u can do wid an internal
internal ones r around rs.2000 a lil up n down....wid dem, u can c tv, record tv, wid sum u can hear n record FM
if dey got the supported ports, u can use them 2 record video from a camcorder or VCR and then after getting them onto ur pc, u can make vcds or dvds out of them
u can do all the same stuff wid external ones more...they dont need an external power source, its powered thru USB itself...i think u need to hav USB 2 for this...and its a lil more expensiv.
the best external one rite now is the pinnacle pctv usb2 100e...and that is around 5-6K....
both hav remotes wich perform a lot of functions
i would say u shud go for pinnacle tv tuners...dey got both internal n external
and the software they supply 2 view tv is quite good
a plus point for external is that if u got a laptop, or more than one computer, etc u can jus pik it up n connect to the other one
incase u wanna record something and ur 1st pc is full, u can attach 2 ur 2nd pc and record
ishaan is offline
Old 18-12-2005, 08:28 PM   #5 (permalink)
i'm a little budgety on this. any thing like 2k may be OK
sagargv is offline
Old 18-12-2005, 09:36 PM   #6 (permalink)
So u want a internal....
I suggest
Compro Video Mate PVR/FM
or
Mercury....
As they are feature rich and winner of Digit Zero Awards.
If external
pctv usb2 100e is best...
Computer.
Whats that.
Old 19-12-2005, 02:57 PM   #7 (permalink)
pinnacle has good internal ones also
i think its called pinnacle PCTV plus
ishaan is offline
Old 19-12-2005, 02:59 PM   #8 (permalink)
pinnacle
Shwetanshu Srivastava
shwetanshu is offline
Old 20-12-2005, 06:39 PM   #9 (permalink)
Is the sound quality of FM fine?? Do those tuner have any antenna??
jack// ani is offline
Old 21-12-2005, 08:39 PM   #10 (permalink)
no antenna sumhow it catches FM thru d cable wire or something like dat but d quality depends on d location
wen my pc wz in d basement lesser quality but on d upper floor its fine
ishaan is offline
Old 21-12-2005, 10:39 PM   #11 (permalink)
Biplav's Avatar
i got a frontech tv tuner internal.
Rs-1200 i think rite now.
pretty gud
really cute remote.
doesnt offer me things substantial like pinnacle but who needs? i just need to watch tv and record.
it does pretty gud job and is the most economical.
Biplav is offline
Old 24-12-2005, 09:08 PM   #12 (permalink)
Default Media center
Please tell me which Internal tuner card support Media center 2005 Edition. This is for future proofing purpose.
navino87 is offline
Old 25-12-2005, 08:55 AM   #13 (permalink)
as long as there is usb support and driver that supports windows xp, there is no need to worry abt windows xp prof. or corp or mce or an sp2 release. they wud be configured for all versions of XP.
/legolas
legolas is offline
Old 25-12-2005, 12:32 PM   #14 (permalink)
bala4digit's Avatar
compro videomate gold!
BEST....at Rs.2500
\"I\'ve Got A Great Ambition To Die Of Exhaustion Rather Than Boredom.\"
\"Where Would You Go When You Can\'t Forget The Past And You Don\'t Know The Future.\"
bala4digit is offline
Old 25-12-2005, 03:52 PM   #15 (permalink)
Yeah I have this one.
And it rocks...
But...
Bundled software is disappointing. U cant watch TV in 98.
I use WinDVR to watch tv in 98.
Computer.
Whats that.
- by gohan89
