Old 16-10-2004, 10:07 PM   #1 (permalink)
Default Recording TV prog using PC
Hi
I've heard that its possible to record TV programs using PC.. How do i go about doin this?..
What alll shd i buy and how do i do?...
SmoothCriminal is offline
Old 16-10-2004, 10:35 PM   #2 (permalink)
get a tv tuner card for one
then we'll talk
No Mercy, No Limits.
theraven is offline
Old 16-10-2004, 11:04 PM   #3 (permalink)
Default m..
Hey man..
I enquired my friend abt TV tuner card.. Are there many types, and which type shd i get for this purpose..?
Old 17-10-2004, 12:57 AM   #4 (permalink)
what do u mean types ?
a tv tuner card lets u watch tv on ur pc
now the only types i am aware of is internal and external
either should be fine
external tuners have added features like watching tv on ur monitor without puttin ur pc on .. but this is only in some models and companies
make sure its a good company like pinnacle as this will define ur quality of capture ...
get a good software to go with it which will be bundles with ur card
and u should be good to go
theraven is offline
Old 17-10-2004, 02:23 AM   #5 (permalink)
Go for an ATI agp/tvtuner card.
Well worth it
amitsaudy is offline
Old 17-10-2004, 10:15 AM   #6 (permalink)
Medic on Call!!
medpal's Avatar
u need a tv tuner card to record programms on tv.
i would recommend pinnacle pctv plus / pro which ihave been using for a long time and it allows you to record in mpeg format and many other formats.
one more thing if you can get a graphice card to go with it that will improve your system performance and while racording make sure you get the full strength signal on the card.
medpal is offline
Old 17-10-2004, 11:53 AM   #7 (permalink)
Default is that enough!
well guys many answers but i think none 100%
i think it is better not to drop text over ...
Any way i am unaware about it and asking
Is ,having Tv card enough?or we need other capute cards and so i have heard that with out capture card even Tv card only doesnt work well and takes some hour to records come programs
So do any real genius have any real idea about the problem.
Just give some real answers ok
Frank
nepsan is offline
Old 17-10-2004, 11:54 AM   #8 (permalink)
Ati AIW or all in wonder cards r gr8 but are costly. U can search for 9600 series based AIW's but a cheaper and better solution would be TV tuner card.
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
- by gohan89
