Old 15-12-2005, 03:41 PM   #1 (permalink)
Default HOW TO MAKE PC FASTER
TELL ME HOW TO MAKE MY PC FASTER FOR PLAYING GAMES
MY CONFI
INTEL 845 BOARD
INTEL P4 2.4 PRO
256 266 MHZ RAM
80 GB HD
sonu_mittal1 is offline
Old 15-12-2005, 03:42 PM   #2 (permalink)
buy a good graphics card
the good companies are ATI or NVIDIA
ishaan is offline
Old 15-12-2005, 07:27 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
well u have soo many posts on the same system
next time make sure tht all are on one thread
it will be easier to answer
add a GFX card as suggested in the other thread
vijay_7287 is offline
Old 16-12-2005, 01:28 AM   #4 (permalink)
yes decide your budget and depending upon that get yourself a goodgraphics card preferably Nvidia
satyen_abrol is offline
Old 16-12-2005, 09:58 AM   #5 (permalink)
if u cant get a new graphics card try lower the resolution of de games n play...
player2k5 is offline
Old 16-12-2005, 02:27 PM   #6 (permalink)
Distinguished Member
anandk's Avatar
try game xp
http://www.thinkdigit.com/forum/view...952&highlight=
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 16-12-2005, 07:59 PM   #7 (permalink)
an another way is u can try to check for spyware making sure everythin is workin perfectly n there r no spyware,malware grayware..use apps like registry mechanic and a good antivirus programme check for viruses i think that would do u a lot good than u expected cheers!!
Old 16-12-2005, 09:15 PM   #8 (permalink)
For u all..
There is a information...
U all say about adding a gfx card but do u know that some older intel 845 chipset even doesnt have a agp port.
Computer.
Whats that.
Is it some kind of frog.. turr turr turrr...
con_tester is offline
Old 16-12-2005, 11:00 PM   #9 (permalink)
yea but contester u can alwayz add a pci slot graphics card rite?..ive heard a few wid very good performances
Old 16-12-2005, 11:28 PM   #10 (permalink)
yes PCI slots can be used for graphics cards...infact AGP slot is a type of PCI
slot only...
Old 18-12-2005, 02:37 AM   #11 (permalink)
dIgItaL_BrAt's Avatar
but PCI graphics are extremely difficult to find these days.
dIgItaL_BrAt is offline
- by gohan89
