Old 15-12-2005, 03:16 PM   #1 (permalink)
Default pc does not start.........
some times my pc starts and while playing games it stops working and get power off while there is light in board but fan is not spinning. some time at startup it works for 10 seconds while loading windows and booting it stops working. also now there is light in board but fan not working. my configuration
intel board 845
intel p4 2.4
256 266 mhz digital ram
intex power supply....
help me..........................
sonu_mittal1 is offline
Old 15-12-2005, 03:51 PM   #2 (permalink)
Check your RAM module for dust and see if it is seated properly. Then, check if all the cables are connected properly... Finally, check if your power supply is working properly through a service engineer...
Arun
sakumar79 is offline
Old 15-12-2005, 03:56 PM   #3 (permalink)
i usd 2 hav d same prob long ago and as sakumar79 suggested, RAM was the cause of it
take it out, make sure its clean, put it back securely
ishaan is offline
Old 15-12-2005, 05:27 PM   #4 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
MOST PROBABLY it is ocurring due to non-functional processor fan. bcoz as processor's temperature increases, the system shuts down itself to protect processor from burning......happens with most people.....get it checked.
gagan007 is offline
Old 15-12-2005, 05:32 PM   #5 (permalink)
::cyborg::'s Avatar
yeah right clean ur ram gold portion with a small piece of newspaper be careful not to touch ram as bcoz of electostatic charge can leave ur ram waste
::cyborg:: is offline
Old 15-12-2005, 07:13 PM   #6 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
looks like a RAM prob
vijay_7287 is offline
Old 16-12-2005, 10:07 AM   #7 (permalink)
gagan007's Avatar
NO Ram problem, it just cant be, bcoz then the PC wont start even....moreover it wud give beep thrice (in case or bad ram), also even if PC starts and u have some bad RAM module then from my experience, u'll get BSOD after sometime.....
gagan007 is offline
Old 16-12-2005, 11:35 AM   #8 (permalink)
Check if power cables & IDE cables are properly connected.
LordDJ is offline
Old 16-12-2005, 11:56 AM   #9 (permalink)
sms_solver's Avatar
it seems like u have problem with the processor or with its fan or both.
Remove the fan and processor and again put it back, if u don't know how to do it, then take help from the technician
One problem could be your fan might not have proper connection with the processor.
There is always light in the motherboard even if you switch your computer off. As long as there is AC power to power supply there will be light in the motherboard. It is not any issue.
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 16-12-2005, 08:04 PM   #10 (permalink)
i just recently had that kind of a prob actually my prob was a little different my comp wasnt switchin on got the mobo replaced a new 845gvsr everythin seems to be in place now
player2k5 is offline
Old 16-12-2005, 09:12 PM   #11 (permalink)
*IF* at all theres a hardware problem it lies within ur smps or motherboard ...
alternatively it *COULD* be overheating ... but in that case when u start it should show "recovered from thermal event"
No Mercy, No Limits.
theraven is offline
- by gohan89
