Old 15-12-2005, 10:37 AM   #1 (permalink)
neerajkumar_4's Avatar
Default Slow…………….. Slow
My pc is kinda slow now a days, it was not that slow when it was new and I had re-installed my OS recently.
My config. Is Athlon XP 2100+ 1.7 GHz
256Mb RAM
BIG Ge-force FX 6200 256 MB
40 GB HDD
I frequently scan my HDD for any security threats, I use defragmenter & disk clean up.
I have only few games installed
So so so y is my PC slow ……it takes time open my computer or my documents also plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz help
★ﮚÇôrp!ŏ_g@m£®™: "There is No such thing as GAME OVER so keep Gaming" :)
Indian Gamers Guild: http://www.gamespot.com/pages/unions/forums/show_topics.php?union_id=IGG
neerajkumar_4 is offline
Old 15-12-2005, 12:22 PM   #2 (permalink)
Traceur
zegulas's Avatar
Use these softwares to keep ur PC neat and tidy...
1. O&O Defrag- For defragmentation (The best tool for defraging)
2. Spyware Doctor- For removal of Sywares.
3. Ad-Aware SE Personal- For removal of Adwares.
4. Any antivirus u like- For removal of Viruses.
5. Windows Registry Repair Pro- For cleaning the Registry.
U CAN FIND ALL TEHSE SOFTWARES IN DIGIT's DVDs AND CDs.
Parkour: A journey started by two & followed by many...
zegulas is offline
Old 15-12-2005, 04:27 PM   #3 (permalink)
u mite hav spyware installed...u can use spyware doctor as zegulas sed, u can also try microsoft anti spyware
maybe a lot of unnecessary processes r running in ur pc...do CTRL+ALT+DEL and select processes on top.
then go to www.processlibrary.com and see wich ones r useless and close them.
if ur toking about boot time, reduce the number of startup items by going to START>RUN and type msconfig
then go to the startup tab
ishaan is offline
Old 15-12-2005, 05:33 PM   #4 (permalink)
::cyborg::'s Avatar
spyware and viruses is the only answer and its 100% guaranteed
::cyborg:: is offline
Old 15-12-2005, 07:17 PM   #5 (permalink)
sidewinder's Avatar
Default Re: Slow…………….. Slow
256Mb RAM
40 GB HDD
post a screenshot of ur task manager..then we can understand what is going on...may be u hav too many softwares running in background...antivirus+firewall+2-3 more softy nd ur pc will go slow with 256 mb ram...
Bombina rocks
sidewinder is offline
Old 15-12-2005, 08:12 PM   #6 (permalink)
speedyguy's Avatar
well normally its due to virus n spywares which u dun realise wen it comes....spy can be identified if u post that screenshot.....i recon u get some anti-virus n spy removal tools....or if u can go this far...backup ur imp files on a friends hdd....clean ur hdd wit a complete format....reinstall os (win xp sp2 recomended for best protection).....n all that process.....this shud work. gud luk
cheers
No Pain...No Gain
speedyguy is offline
Old 15-12-2005, 08:32 PM   #7 (permalink)
Distinguished Member
anandk's Avatar
ur pc is slow :
ok, do this.
get a pc junk cleaner
'ccleaner' is one good freeware. www.ccleaner.com
else use 'ace utilities' or tune-up utilities or system mechanic.
get 1 good antivirus
avast - www.avast.com
or avg - www.grisoft.com
are good freeware programs.
download, install, update, run in safe mode the fist time.
u also need 2 anti-spywares
i suggest microsoft antispyware and
spywaredoctor 3.1 or adware or spybot.
download, install, update, run them in safe mode the fist time.
defrag ur registry as well as ur hard disk.
want more ?
get 'driver heavens tunexp 1.5' and use the tool.
'bootvis' and 'cacheman' will also help u.
these links will help u
http://www.techsupportalert.com/best..._utilities.htm
www.download.com
http://mywebpages.comcast.net/SupportCD/OptimizeXP.html
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 16-12-2005, 01:51 PM   #8 (permalink)
hey listen guys i hav norton anti-virus 2003 and spybot1.4 all up to date ( & scanned ) and can any 1 tell me how to post a screenshot so that i can show u all my processes??????????
Old 16-12-2005, 01:53 PM   #9 (permalink)
i hav adware too
Old 16-12-2005, 02:23 PM   #10 (permalink)
anandk's Avatar
download 'hijackthis' from here
http://www.filehippo.com/download_hijackthis/
run the tool, save the logfile, and copy paste it here. sum1 will help u !
Microsoft® MVP
anandk is offline
Old 17-12-2005, 02:56 PM   #11 (permalink)
ok heres the log list u wanted to c
Old 17-12-2005, 02:57 PM   #12 (permalink)
its kinada big ok plzzzzzzzreply and help me guyss
Old 17-12-2005, 02:58 PM   #13 (permalink)
Logfile of HijackThis v1.99.1
Scan saved at 2:55:08 PM, on 12/17/2005
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
C:\Program Files\Common Files\Microsoft Shared\VS7Debug\mdm.exe
C:\Program Files\Norton AntiVirus\navapsvc.exe
C:\Program Files\Norton AntiVirus\AdvTools\NPROTECT.EXE
C:\WINDOWS\system32\nvsvc32.exe
C:\WINDOWS\system32\slserv.exe
C:\Program Files\Common Files\Symantec Shared\Security Center\SymWSC.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\Program Files\Java\j2re1.4.2_05\bin\jusched.exe
C:\Program Files\Common Files\Real\Update_OB\realsched.exe
C:\WINDOWS\system32\ctfmon.exe
C:\WINDOWS\system32\rundll32.exe
C:\WINDOWS\system32\slrundll.exe
C:\WINDOWS\system32\CMMON32.EXE
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\WINDOWS\system32\ntvdm.exe
C:\Program Files\Messenger\msmsgs.exe
C:\Documents and Settings\User\Desktop\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.gamespot.com/
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - D:\PROGRA~1\SPYBOT~1\SDHelper.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar2.dll
O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:\Program Files\Norton AntiVirus\NavShExt.dll
O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:\Program Files\Norton AntiVirus\NavShExt.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar2.dll
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [ccRegVfy] "C:\Program Files\Common Files\Symantec Shared\ccRegVfy.exe"
O4 - HKLM\..\Run: [Advanced Tools Check] C:\PROGRA~1\NORTON~1\AdvTools\ADVCHK.EXE
O4 - HKLM\..\Run: [Cmaudio] RunDll32 cmicnfg.cpl,CMICtrlWnd
O4 - HKLM\..\Run: [VTTimer] VTTimer.exe
O4 - HKLM\..\Run: [Symantec NetDriver Monitor] C:\PROGRA~1\SYMNET~1\SNDMon.exe /Consumer
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RunDLL32.exe NvMCTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\j2re1.4.2_05\bin\jusched.exe
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe" -osboot
O4 - HKLM\..\Run: [B-Reader] C:\Program Files\Harshil's Softwares\Birthday Reminder\B-Reader.exe
O4 - HKLM\..\Run: [A-Reader] C:\Program Files\Harshil's Softwares\Birthday Reminder\A-Reader.exe
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O8 - Extra context menu item: &Google Search - res://c:\program files\google\GoogleToolbar2.dll/cmsearch.html
O8 - Extra context menu item: &Translate English Word - res://c:\program files\google\GoogleToolbar2.dll/cmwordtrans.html
O8 - Extra context menu item: &WordWeb... - res://C:\WINDOWS\wweb32.dll/lookup.html
O8 - Extra context menu item: Backward Links - res://c:\program files\google\GoogleToolbar2.dll/cmbacklinks.html
O8 - Extra context menu item: Cached Snapshot of Page - res://c:\program files\google\GoogleToolbar2.dll/cmcache.html
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O8 - Extra context menu item: Similar Pages - res://c:\program files\google\GoogleToolbar2.dll/cmsimilar.html
O8 - Extra context menu item: Translate Page into English - res://c:\program files\google\GoogleToolbar2.dll/cmtrans.html
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\j2re1.4.2_05\bin\npjpi142_05.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\j2re1.4.2_05\bin\npjpi142_05.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRA~1\YAHOO!\MESSEN~1\YPAGER.EXE
O9 - Extra 'Tools' menuitem: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRA~1\YAHOO!\MESSEN~1\YPAGER.EXE
O9 - Extra button: eBay - Homepage - {EF79EAC5-3452-4E02-B8BD-BA4C89F1AC7A} - C:\Program Files\IrfanView\Ebay\Ebay.htm
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
O17 - HKLM\System\CCS\Services\Tcpip\..\{025AF20D-817A-475A-9E65-4E91CE777262}: NameServer = 61.1.192.65 61.1.128.5
O17 - HKLM\System\CS1\Services\Tcpip\..\{025AF20D-817A-475A-9E65-4E91CE777262}: NameServer = 61.1.192.65 61.1.128.5
O23 - Service: Adobe LM Service - Unknown owner - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
O23 - Service: Symantec Password Validation Service (ccPwdSvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccPwdSvc.exe
O23 - Service: Norton AntiVirus Auto Protect Service (navapsvc) - Symantec Corporation - C:\Program Files\Norton AntiVirus\navapsvc.exe
O23 - Service: Norton Unerase Protection (NProtectService) - Symantec Corporation - C:\Program Files\Norton AntiVirus\AdvTools\NPROTECT.EXE
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: ScriptBlocking Service (SBService) - Symantec Corporation - C:\PROGRA~1\COMMON~1\SYMANT~1\SCRIPT~1\SBServ.exe
O23 - Service: SmartLinkService (SLService) - Smart Link - C:\WINDOWS\SYSTEM32\slserv.exe
O23 - Service: Symantec Network Drivers Service (SNDSrvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
O23 - Service: SymWMI Service (SymWSC) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\Security Center\SymWSC.exe
Old 17-12-2005, 04:28 PM   #14 (permalink)
Laptoping
Sourabh's Avatar
Easy mate, just edit the previous post instead of posting it as a separate post from next time. These are some unsaid basic forum rules.
Hope you get the point.
Sourabh is offline
Old 18-12-2005, 02:22 PM   #15 (permalink)
alib_i's Avatar
neeraj,
Your HijackThis Log is clean
and you've said you defragment and clean your drive regularly too ...
So I think nothing's wrong in this respect.
but you can think of turning OFF a few unneeded services ..
there are many threads in this respect available in the forum .. try searching a few.
alibi
-Metallica
alib_i is offline
Old 19-12-2005, 05:09 PM   #16 (permalink)
plz tell me clearly as to what should i do..??
and wat do u mean by threads????????
plz reply soon......
thanx in advance
Old 19-12-2005, 05:11 PM   #17 (permalink)
Commander in Chief
QwertyManiac's Avatar
Threads are topics in other words
Disable any service u find useless in msconfig and services.msc
Harsh J
www.harshj.com
QwertyManiac is offline
Old 19-12-2005, 05:18 PM   #18 (permalink)
thanx but i think all r useful 1s and it takes me around 10 -15 secs for my desktop ot load is it normal os not??
Old 19-12-2005, 05:19 PM   #19 (permalink)
Commander in Chief
Its super normal ! Then y is ur comp slowww ?
Harsh J
www.harshj.com
Old 19-12-2005, 05:23 PM   #20 (permalink)
hey but some times my computer takes time ot load
Old 19-12-2005, 05:24 PM   #21 (permalink)
__Virus__'s Avatar
wweb32.dll
Vttimer.cpl
What are they, google refuses vttimer.cpl as input :roll:
__Virus__ is offline
Old 19-12-2005, 05:25 PM   #22 (permalink)
hey plz check out my log file which posted and tell me which anti-virus process should i kill in order to remove it from my system tray .............
Old 19-12-2005, 05:26 PM   #23 (permalink)
i guess my system gets a lot slower coz of my NAV 2003 if switch over to 2005 will the problem perist??
Old 19-12-2005, 05:28 PM   #24 (permalink)
__Virus__'s Avatar
Dood y don't you edit your posts using Edit button?
Old 19-12-2005, 05:30 PM   #25 (permalink)
k thanx a lot guyssss hey and if i remove the tray icon will the NAV2003 detect virus threats, i mean the auto protect feature
Old 19-12-2005, 05:31 PM   #26 (permalink)
Commander in Chief
Dude.. dont post consecutivelly... use the EDIT button u see...
NAV 2005 hogs more memory than the 2003... if u really want norton then go for the 2006 version.. its a lot faster than 2005 and is almost as good in speeds as 2003
also.. to disable the tray agent do this :
Norton Antivirus > Options > under the Autoupdate tab (ususally the first page) uncheck the box marked Show Auto-Protect icon in tray. and save thee settings
Harsh J
www.harshj.com
Old 20-12-2005, 10:22 PM   #27 (permalink)
which processs should i remove to stop NAV ???
- by gohan89
