Old 14-12-2005, 05:46 PM   #1 (permalink)
U2
Default two options
hey i had just formated the 2 of the partitions(computer) and installed windows xp...the problem is that when i start the computer there are 2 options for windows.....when i started windows and went to drive d there i found tht it had only doc&settings folder and windows folder....while the other drive had doc&settings folder and windows folder and program files folder.....i this that the drive d is curropt and want to cleane it and remove the option to select windows which comes when i start computer
hey my previous id was readermaniax
U2 is offline
Old 14-12-2005, 07:00 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
is it like u r able to boot into both the options which r shown while boot up
anyways get the OS on the c drive
goto system properties>advanced>startup and recovery>settings
there u edit the boot file and remove the unwanted option
looks like u did the installation twie over, stopping one in the middle
and then u can go abt formating the d drive
vijay_7287 is offline
- by gohan89
