I personally prefer Flash FXP. It supports resuming, but so do most other FTP clients. Ability to resume failed uploads depends on the server configuration. I think CuteFTP supports resuming, maybe your server is at fault here.
Yea so ? You wanna download with resumes supported then pray tell me why wont it happen via flashget ? Unless your downloading content which uses FTP invisible folder tagging and other features then in which case Flashfxp or Smart FTP all the way. Why do u need a FTP client if all you do is download ????!!!!!! :roll: :roll:
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
I have 3 dedicated server located in different area, are all of them faulty?
Yes, all the three servers have resume support turned off. Most server admins keep resume functionality switched off to avoid uneccesary incomplete files on the harddisk, the moment a transfer fails the unfinished file is deleted from the server to reclaim space.
