well you can use this to spy or just have plain fun for recording your chats, or use is to podcast as most of them are doing....
the software required >
Hotrecorder
http://www.hotrecorder.com/
The Description on the site >>
_________________________
HotRecorder for VOIP is an advanced technology that allows you to effectively record, play, store and add sound effects (Emotisounds) on voice communications held over the Internet. It also includes voice mail for Google Talk and Skype ™ !
HotRecorder for VOIP is a unique application that works in conjunction with Google Talk, Skype ™ , AIM ™ , Net2Phone ™ , Yahoo! Messenger ™ , FireFly ™ and many other VoIP applications.
If you have any doubt about the application you frequently use, don't hesitate to contact us . (support@HotRecorder for VOIP.com)
HotRecorder for VOIP is a recording tool very easy to download, install and use that will enhance your experience with the products you already enjoy using daily.
The Experience >>
________________
good points::
> Well it's free and works fine, with skype and gtalk.
> how will you hear the two people talking at the same time when playing back, simple..the left channel is one person and right channel is one person.
>in one voice chat i kept the recorder on for half and hour and it recorded all of it, yup totally free and unlimited recording time.....
> good compression.
weak points::
>when u do record the window cannot be minimised, ah but i found an alternative.....zhider......this little app will hide any app with the [ctrl+alt+z] combi, and the hotrecorder will be hidden.....
[zhider >
http://www.snapfiles.com/get/zhide.html]
> the recording done with hotrecorder can only be played back the same software, u need to buy the software to convert it to mp3 etc....
__________________________________________________ _________
hope u guys like this recommedation..
