Old 16-10-2004, 04:30 PM   #1 (permalink)
Default NEED HELP URGENTLY !!!!
hello everyone.....i really need ur help. Did anyone get the new Digit? the one with the DVD? and did u try installing America's Army? becoz for me it doesnt work. it just gets stuck and displays an error something like the memory code is not complete...by the way wat software do u use to install it? Winzip, Winrar or somethin else?? Please help me as soon as possible.
Thanks a lot
tHe_WiCkEd_OnE is offline
Old 16-10-2004, 05:51 PM   #2 (permalink)
144
144's Avatar
Can you give more info on your comps spec + Exact error message ? you've said:
"something" is not accurate. If you can be more precise you could get more help responses.
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
Old 16-10-2004, 05:59 PM   #3 (permalink)
144
144's Avatar
See if your system meets the Minimum Sys Requirements
144 is offline
Old 16-10-2004, 11:10 PM   #4 (permalink)
ok thx for your response... my PC seems to be well above the requirements .. anyways i willl tell u -
Acer Aspire G600
2.4 Ghz
512 MB RAM
64 MB VRAM
and i have a Pioneer DVD Drive. i can play all high-end games like Far Cry, Halo, Call of duty,etc.. and they run smoothly. Oh yeah and the exact error message when i double click on it is as follows below..
Before it used to come like something about the code being incomplete but now i got a new DVD and this is what comes-
D:\Digital Leisure\Games\Big Games\AmericasArmy210_Download.exe
is not a valid Win32 application.
I think it is some software problem and not with the DVD.
And can u tell me how u exactly installed it and wat installer u used?
and do u need to decompress the file?
Looking forward to your reply
Old 16-10-2004, 11:41 PM   #5 (permalink)
oh now when i rebooted my pc the previous error message came. it is as follows -
"Only part of a ReadProcessMemory or WriteProcessMemory request was completed"
do u have any idea wat it means??
Old 16-10-2004, 11:48 PM   #6 (permalink)
could be installation file corrupted on the dvd
try
- copy the folder or file from dvd to hdd and run install .
- i assume xp so , check event viewer for exact error msg and post it here .
- ran it with integrated unicrome graphics and it worked in low details
- check the usual , dxdiag , updated graphics drivers , disable antivirus while installing
- check if u have cdrom or atapi event viewer errors . try switching ide cables .
- try going to safe mode and copy the file to hdd
do tell the results to troubleshoot further
klinux is offline
Old 21-10-2004, 03:25 PM   #7 (permalink)
Bewitched!
xenkatesh's Avatar
Check ur graphics card if it is supporting that game requirements!
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
- by gohan89
