Old 13-12-2005, 01:45 PM   #1 (permalink)
doom_marine's Avatar
Default Bittorrent Problems
I used to have a USB Cable modem for my internet connection and when i used bittornado i used to get 50 - 51 KB/s download, lately my isp changed the modem to a normal ethernet modem which is connected to LAN port instead of USB. Since then my transfer where always slow max out at 20KB/s and the yellow light never changes to green (connected status). Could someone help me get the same download speed again plssss...
AMD Athlon X2 4200+
2GB DDR 400 RAM
nVIDIA 7800GTX 512MB x 2 SLI
Creative X-Fi Fatal1ty Sound Card
400+160+74GB HDD SPACE
doom_marine is offline
Old 13-12-2005, 03:26 PM   #2 (permalink)
siriusb's Avatar
You need to port-forward the port that you are using in BT. Your ethernet modem will probably allow you to telnet into it and change settings. Or it might give a webpage interface by allowing you to type it's address (usually 192.168.1.1) in a browser.
Try doing it or reply with the name of the modem.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 13-12-2005, 04:58 PM   #3 (permalink)
doom_marine, wat internet conx are u having??
/legolas
legolas is offline
- by gohan89
