Old 16-10-2004, 01:50 PM   #1 (permalink)
Default Make Acrobat Reader 6 load faster
Here's how to do it:
1. Go to C:\Program Files\Adobe\Acrobat 6.0\Reader (replace the C if you installed on another drive, like I did).
2. Create a new folder called plug_ins_disabled.
3. Move all files from the plug_ins folder to the plug_ins_disabled folder except EWH32.api, printme.api, and search.api. There should only be these 3 files in the plug_ins folder.
4. You're done.
(Courtesy of Darrell Norton)
UPDATE:
Adobe made a predefined folder for unused plugins, called "Optional" (see the readme file there).
u might want to move all the plug-ins that you want disabled into the "Optional" directory instead of making "plug_ins_disabled". This way the plug-ins will still work, they just won’t be loaded at startup...
So do this instead:
3. Move all files from the "plug_ins" folder to the "Optional" folder
3. You're done.
Another way
You can bypass the loading of plug-ins by holding down the
<Shift> key when the Reader starts. The difference in load time would be
amazing.
Shermina
Edit: [enoonmai] : Please read the rules regarding signatures. Only text signatures of 4 lines/255 characters are allowed.
sara2002 is offline
Old 16-10-2004, 02:15 PM   #2 (permalink)
Basically u disable the plugins from loading at startup
Walk on the Wild Side. The other side SUX!!!
krazydude is offline
Old 16-10-2004, 02:51 PM   #3 (permalink)
Have seen this long ago in Tech-Arena forums.
Anyway thanks for the info. I needed that.
zeeshan_04 is offline
Old 16-10-2004, 03:08 PM   #4 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
You can also use Acrobat Reader Speedup for that ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
- by gohan89
